motor dies when getting out of freeway???
I need help on my 92 ES300. The engine will die very often when getting out from freeway, or sudden stop. Restart the car, then OK. Sometime I did not notice until I tried to hit the gas pandel. Any sugestion will be appreciated.
Please send reply to walterphan@hotmail.com
I had the same problem... make sure your engine mounts are not worn and causing a split in the air intake inlet.
The engine mounts on mine wore down so bad the engne moved alot in the engine bay causing theair intake to split .. then when i pulled away for sudden stop the engine would cut out
Sounds Like The Problem
Just my 2 pennies worth!
Scott.
I experienced the problem again...
I have not replaced the air intake inlet yet.. just taped it for the time being. I have also got to replace the bottom engine mount too (hoefully do both together)
I was driving back from London and had to break real heavy and i could feel the engine dying... but when i removed my foot of the brake everything was ok.
Technics
Performance & Maintenance
10-11-04 05:19 PM
