Fujistu ten
Fujistu ten
Hi all, I've got a 93 vcv10 windom/es300 its got the fujitsu ten head unit in it and I'm looking to replace it with my pioneer unit, does anybody have a wiring diagram for this? I've searched and searched to no avail, nothing seams to have this factory unit in it. it has one complete plug with 15 pins, looking at the back of the head unit is:- top [- - - I - - - -] and at the bottom of the plug hole is [- - I - - - - I - -]. also it does have the amp under the seat but that is the easy bit. cheers.
so you need to know what color wires go where? It is the stock one correct? It is kind of late to look at my car's wires but I'll see if I can let you know what wires are which to the best of my extent. But my car is kind of rigged differently, I think the last person that did it might of changed the wires, I know that my wires are tagged to let you know which speakers they are going to.
Mate.....
That would be excellent if you could, Mine only has tape and AM/AM and seeing as I dont own any tapes any more and cant stand all the talking on the radio I'm in a bit of pickle.
I looked at it and just about cried, I've done the battery test across all of the wires and cant get any "pop"from the speakers.
cheers.
cheers.
Oops... mistake made.
14 pin is actually correct.
this is the wires I have.
1- pink/blue stripe
2- green (thicker)
3- blue/red stripe
4- red
5- brown
6- blue
7- black
8- black (thicker)
9- black (thicker)
10- brown (thicker)
11- white
12- red (thicker)
13- yellow
14- green
1- pink/blue stripe
2- green (thicker)
3- blue/red stripe
4- red
5- brown
6- blue
7- black
8- black (thicker)
9- black (thicker)
10- brown (thicker)
11- white
12- red (thicker)
13- yellow
14- green
This is as much info that I can get without breaking my wires, from my 93 ES.
Blue/grey stripe- Front right (+)
Yellow/ Grey stripe- Front right (-)
Brown/grey stripe- Rear Right (+)
Red/grey stripe- (Rear right (-)
Green/ grey stripe- Front left (+)
Black/ grey stripe Front left (-)
Green/red- Switch power (ign.)
Grey/ black- batt.
White/green- ground.
That is all that I can see without ripping my chords out, I hope this is useful. Someone correct me if I am wrong, I don't want to electricute these guys.
Disclaimer: some vehicles may vary, assume being an electrician at your own risk!
Grey/ black- batt.
Thanks mate, I appreciate your going to the effort for me but sadly your colour code is different to mine, many thanks for taking the time though.
I guess I'm going to have to bite the bullet and take it into an audio shop.
Thanks again.
Glenn.
Thanks again.
Glenn.
well as you can seee from my color codes there is a pattern among the wires, that all othe ones with grey stripes are speakers. and other ones can can me other things. oh and you're thickest black wire probably is the antenna
Oh, I think I get it.
They are not grey stripes running the legnth of the wire but like
grey bands dotted up the wire, correct?
If this is right, you my friend are my hero.
and I am the thickest part of the wiring..
yeah bands for better lack of words, sorry. also my colors might be a little off because I looked at night without a flashlight, only the dome lights, the only bands there are I think are grey, and the other ones are like two-colored wires. I haven't looked at the amp yet but maybe the amp can also help on which wires is which.
No problem that is why this forum is here, to help each other out.
GSMIC400
01-22-18 12:58 AM
Volume123
23
03-06-13 05:16 AM
cbreaker
11-29-04 01:04 PM
