'92 - Trunk pop not popping?
I can still open the trunk w/ a key, but the button on the drivers door doesn't have any effect. Any ideas what it might be, how to test?
Lexus Connoisseur
Open your trunk manually, and press the button with the trunk open. If it doesn't function, the solenoid could be out.
same thing on my 92, opened the glove box and pushed the button... then the one on the door... now it works. but strangely only when the car is turned on...
Originally posted by amf1932
That's strange. The trunk button on the newer ES's always worked whether the iginition was on or off. Maybe the '92 ES's were supposed to work that way???
I checked the button in the glovebox, and it was switched off. It then worked for 2 weeks, but now doesn't work again. Now though, the button is set correctly (actually doesn't work no matter what position I've got it in.
Fuse?
Fuse?
