Airbag reset
Airbag reset
I changed out my battery this weekend, the airbag light stays on. Has anybody done a reset themselves?
Or is this a dealer service.
Any leads on the LED speedo and Tach needles for a 93 es300, 3 are burned out.
I changed out my battery this weekend, the airbag light stays on. Has anybody done a reset themselves? Or is this a dealer service.
Keeper of the light
This is a common problem/issue on all 1st-gen ES's. No easy workaround except entire replacement of instrument cluster from the dealership, which could run to at least $500.
OLT it was a problem that existed in all Camry's from that gen, and corollas (that had airbags) atleast. (probably the entire Toyota line)
All you do is go a Toyota/Lexus dealer and tell the to reset it. Normally it's free down here. I've had it done on a '93 Corolla & this '93 ES when I changed the battery afew months ago... All the Toyota service manuals from that era that I can recall warn that if the battery is disconnected for more than 30 seconds; the airbag computer may need to be reset.
