3 Key Factors To Speed Up Oil Extraction-Engine Oil Change
Also you may not get all the oil this time, but you will get next time. My opinion, it is not a big deal. For those lazy people who don't change their oil often, this is an easy alternative.
There's no good substitute for a conventional oil change where ALL of the oil is drained and a new filter installed. Any impurities contained within the filter simply recirculate through the engine. With the extended oil change schedules now in place they could be in there for a year... Not a good idea IMO.
I love the tree branch dip stick for checking level in the bucket. Can probably "upgrade" the suction to the bucket with an A/C vacuum pump(http://www.autozone.com/test-scan-and-specialty-tools/a-c-vacuum-pump). Autozone loans them. But why loan when you can buy for one easy payment of $300? Can also punch a small hole in the suction tubing, just above the oil level, to allow aspiration of small air bubbles into the tube.
Fun video. Thanks for posting.
Richard
Nah, he does. He posted a video (see below).
https://www.youtube.com/watch?v=woWjjqn-xb0
Richard
Richard
There's nothing wrong with extraction. 99% of an oil change is because the oil loses its ability to provide protection as it breaks down due to heat and stress. By replacing your oil whether it be drain and refilling or extraction, you're doing just that. Of course replace your filter.
As long as the extractor reaches the bottom of the pan (which is where the dipstick goes) then you are emptying the oil. Pay attention to how much oil you refill and if it meets the mark on the stick. If it's the factory specified amount that you put back in AND the mark on the stick is where it needs to be, then your extractor pulls from the correct place. If you're that concerned about sediment at the bottom, then do a drain every 2 or 3 changes. But really that concern is negligible at best. That's what your oil filter and oil pump strainer are for (assuming there's even sediment to begin with) There shouldn't be if you are changing your oil frequently.
I've used this with my BMW for years with great results: http://amzn.to/2exzl9C
Nice to see other car owners extracting the oil without fear. You amazon link of the manual pump says "flex hose", I know what can dipstick hose do, but what does this flex hose do?
- Includes 5 feet of flex hose and two dipstick hoses
05RX330AWD
06-19-17 05:10 PM
rlx101
26
12-22-14 07:27 PM
giantdefy
02-07-10 10:59 PM
