ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Why my es 350 got rust in less than a year.
Old 03-06-13, 01:12 PM
lli22222
lli22222's Avatar
Default Anyone knows ES 350 has rust issue?
I am living in Toronto. I bought an new 2012 ES 350 last April and have driven it for less than 10000 KM, just drive it for daily commute on a high way. Now I noticed that my car already shows a lot of yellow rust dots, in the front and on both sides of front door area, I don’t understand why Lexus has such poor quality of painting? I know we have bad winter here, a lot of salt on the road, but Lexus should handle it better than this, right? Does anyone knows if the similar issue happens to you or your friends?
Old 03-06-13, 09:12 PM
lli22222
lli22222's Avatar
Default Why my es 350 got rust in less than a year.
Old 03-06-13, 09:20 PM
Received 2,522 Likes on 1,820 Posts
My guess is they are just rust spots imbedded in the paint, and that they would come out wi a clay bar.
Is the paint chipped in those spots?
Old 03-07-13, 03:27 AM
2008ES
2008ES's Avatar
How To Create a Smooth Paint Surface
PAC tells how... to create a smooth paint finish
Old 03-07-13, 04:57 AM
mlacomb
mlacomb's Avatar
I have a friend who worked in the car service industry. This could be rail rust - i.e. small particles of metal from the train rails that somehow got embedded in the paint during transport. Saw it happen on another non-Lexus car that I was considering buying. It can be removed with some work - or take it to the dealer you purchased from / get service done and ask if they'll remove it.
Old 03-07-13, 05:51 AM
twistedman
twistedman's Avatar
Happens to my car every winter! When spring arrives i usually spend an hr claying my car removing all the fallout from my paint! The above pic is not my car, but shows how bad it can get if its not removed.. Happens to all cars! But starfire perl white makes it show up Big time.
Old 03-07-13, 05:52 AM
jagtoes
jagtoes's Avatar
Are you sure it is rust and not from the disc brake rotors. Either take it to a detailer or use a little compound and see if it comes off. I had that problem with my white GMC pick up where the normal stop and go would produce flakes of metal which stuck to the paint. I thought the truck was rusting but using a little compound cleaned it up. Worth a look.
Old 03-07-13, 07:50 AM
lli22222
lli22222's Avatar
I brought my car to the dealer today, they told me one of rust spot is cast by paint chipped that need some touch ups, the rest of them are called environmental rust, it is rust but can be removed by wax/clay whatever it called. And they told me it’s normal situation for all cars in heavily salted environment. Since my car is white so it’s noticeable very easily.
From one of post, it could rail rust, that’s a new to me too. It’s good to know though.
Thanks for all your replies,
Old 03-07-13, 08:02 AM
jcat_350
jcat_350's Avatar
clay it, but it could be chips from sand/salt that rusted over.
lexus paint is significantly softer/thinner by comparison to many other manufacturer's paint finishes, and has been for a long time.
Old 03-07-13, 09:06 AM
lli22222
lli22222's Avatar
How often do you clay your ES350, do you do it by yourself? What do you do with the chips?
Old 03-07-13, 09:15 AM
lli22222
lli22222's Avatar
You are right, my car happens to be perl white. Anyway, it's good to know how to handle it. Thanks,
Old 03-07-13, 11:07 AM
jcat_350
jcat_350's Avatar
I clay my car prior to a full detail a few times a year. Usually at the beginning of spring, beginning of summer, at the end of summer, and right before winter. Clay barring is so cheap and easy that I think everyone should do it prior to waxing but after washing their car.
The chips you'll want to get some touch up paint for. It won't look great, but it'll prevent rust and help the chips be a bit more inconspicuous.
The other thing to keep in mind is that using a good SEALANT, not just wax, but SEALANT, will help prevent that stuff from really sticking to the paint and will make it easier to remove with the clay bar.
There is a dedicated detailing forum on this site, check it out for tips and ideas from other members for any range of problems like yours.
Old 03-08-13, 07:41 PM
John U
John U's Avatar
My brand new Pearl White Odyssey looked like this. My first wash started with this Iron X.
http://forums.corvetteforum.com/car-...ted-civic.html
Old 03-08-13, 07:56 PM
Sango
Sango's Avatar
Keep mind mind salt ls like cancer. but on cars so yes, the rust could start appearing like that the more you run on salted roads.
Maljunulo
ES - 6th Gen (2013-2018)
13
03-07-17 10:44 AM
Seniorleb
21
08-29-16 10:41 AM
DShiekhi
04-12-16 04:42 AM
Gojirra99
11-22-06 10:50 AM
badgis
03-23-06 01:03 PM
Quick Reply: Why my es 350 got rust in less than a year.
