ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
List of current ES350 TSIBs
Old 01-27-08, 04:43 AM
  #61
ES350Bob
ES350Bob's Avatar
ES350 engine oil leak, from timing cover.
Sorry guys best I could do is provide the number for it by link with limited details. Maybe someone will post the actual TSIB content which may provide more details.
http://www.lexusforum.com/recalls-an..._01007/TSB.htm
Old 02-17-08, 07:24 PM
  #62
YotaCarFan
YotaCarFan's Avatar
Default EG023-07 Engine idle vibration and drone noise
At long last: A fix for the ridiculous vibrating and noise of the engine while idling in gear.
Production change effective VIN:
JTHBJ46G*82177233
The repair: replace the active motor mount.
Old 02-17-08, 07:28 PM
  #63
YotaCarFan
YotaCarFan's Avatar
Default BR002-07: Rear brake squeal and excessive pad wear
A fix for brakes that squeal when driving less than 10mph and gently braking.
Production change VIN:
JTHBJ46G#82181050
The repair:
Install new design of brake pad.
Old 02-17-08, 07:34 PM
  #64
YotaCarFan
YotaCarFan's Avatar
Default EG001-08: MIL "on" with VVTi DTCs
In some cases, the MIL will illuminate and an error code related to the VVTi oil control valve will be stored.
JTHBJ46G*82169750
The repair:
Replace the affected oil control valve with a newly designed one. This repair involves opening up the engine -- pretty major work. Cross you fingers you don't need this one done on your car...
Old 02-17-08, 07:40 PM
  #65
YotaCarFan
YotaCarFan's Avatar
TSB #EG010-07
JTHBJ46G*72059251
Problem: Oil leaks from area where Bank-1 cylinder head, engine block, and timing chain cover meet.
Repair: Remove the timing chain cover, and reseal it (they use a liquid sealant that's analogous to window caulking).
Old 02-17-08, 07:47 PM
  #66
YotaCarFan
YotaCarFan's Avatar
Default AU001-07: AUX audio port noise
Problem: Playing an MP-3 player through the AUX jack can result in noise/buzzing in audio signal if the MP-3 player is running off vehicle power (e.g., via the cigarette lighter power adapter).
The repair: Add noise filter to circuit. Install newly designed AUX jack.
Affected vehicles:
2007 ES350
2006 - 2007 IS250/350
2007 LS460
2007 LS600h
Old 02-18-08, 02:13 PM
  #67
ES350Bob
ES350Bob's Avatar
JTHBJ46G*82177233
Yota,
Thanks for posting this one, all of them actually, but this one, part of me feels like e-mailing it to several at corporate and one dealer with a few #$@%^&* words for the normal operation of an ES350 claims made.
It is good news for those who had been tolerating it.
Old 02-21-08, 09:02 PM
  #68
pestleman0
pestleman0's Avatar
Default TSB for motor mount
JTHBJ46G*82177233
Several questions here. When looking at the VIN does only the last 6 apply? For example, VIN 177232 would be included but 177234 would not? ((( Does someone have the complete TSB on this motor mount that they could post? ))) Every site I have been on does not have it--> http://www.aboutautomobile.com/tsb/2007/LEXUS/ES350
http://www.badongo.com/file/2216875
http://www.lambros.net/2007LS460L/tsib/
https://www.clublexus.com/forums/sho...=249766&page=3
http://www.alldata.com/TSB/31/07311824.html
http://www.allworldauto.com/tsbs/200...62-2007-1.html
http://lexustsb.com/index.php?action...=4&newslang=en
My VIN is JTHBJ46G*72125360 (2007). Does this mean my VIN would fall under the TSIB for the motor mount? I do experience slight vibration in P and R but just always assumed it was normal. Of course, $40K you would expect not. Thankfully, I have fallen above the VIN's for the transmission (72064871) if I'm reading it right. If my car falls above the VIN cutoff does this mean I should not have the problem? If I do have the problem are they less likelyto fix it if it is above the cutoff VIN? I still need to check under the hood to see if I'm experiencing the oil leak (72059251). Last question, is a flare up to 150-200 rpm normal? I was paying close attention driving home tonight and noticed what seemed to be a flare between 2nd and 3rd.
Old 02-22-08, 06:07 AM
  #69
ES350Bob
ES350Bob's Avatar
Yes your car does fall within TSIB for motor mount, see the 8 in TSIB listed VIN, that is an 08 produced car.
And no your transmission is not immune and do not go by that VIN cutoff anyway for trans as several 08 owners have had the trans problem. There have been several trans tsib including with VIN cutoff and the problem was still present built after that cutoff.
As to gear 2 to 3 you mentioned, no it is not normal, that's how they start off and/or is a function of throttle level, if slow accel they can be small like that.
Do NOT fool around with one where you believe it is 2 to 3 because you MUST have that working properly when pulling out into traffic as opposed to 3 to 4 where you are at least up to a reasonable speed when it slips. Keep an eye on it for now if you have only noticed it the one time but if you see it again demand they do something about it.
Old 02-22-08, 02:28 PM
  #70
pestleman0
pestleman0's Avatar
Sometimes the answer is right there in front of me but I fail to believe it. I noticed a 300rpm flare between 3rd and 4th this morning. Your right, the VIN above the cutoff are not immune. I have an appointment to drop it off at the dealer tomorrow on the motor mount and flare. I guess we'll go with the re-flash and see if it helps. If it continues after that then I will demand a new transmission. My car has probably been doing it since I got it but was not educated on what to look for. It now has 9K on it with manufacture date of 04/01/07. So subtle, but I'm sure can become a disaster after the warranty is up. Gives me some food for thought about the extended warranty.
On another note, is it normal for the visor light to shut off when the visor is pushed all the way toward the window? I noticed there was a TSB for the flicker. Mine doesn't flicker it just turns off. The lights inside this car are horrible. I have to open the visor to get the adequate lighting when needed. Anybody have any updated TSB's that they could post? I am specifically looking for the entire detailed TSB's.
Old 02-25-08, 07:35 PM
  #71
pestleman0
pestleman0's Avatar
Dealer contacted me today saying the motor mount has been ordered and they will be doing the re-flash on the transmission tomorrow. Fingers crossed.
Old 02-26-08, 02:41 PM
  #72
YotaCarFan
YotaCarFan's Avatar
Let us know whether the new motor mount actually reduces vibrations in the steering wheel when the car is idling in gear. Mine did not. However, the dealer said the replacement mount was one they had ordered earlier for a previous customer who never came back to have it installed, so I'm wondering if they gave me one of the old versions of the mount.
Old 04-15-08, 06:51 AM
  #73
pestleman0
pestleman0's Avatar
Well, the vibration is still the same. I may get them to do it again on the next oil change. So far, the flash on the transmission has taken care of the flares. It is worth noting that the flash was done at the end of winter so the real test will come next winter. So far so good though.
Old 05-21-08, 06:53 PM
  #74
YotaCarFan
YotaCarFan's Avatar
Default L-SB-0027-08: Torque Converter Shudder
Issue: Vehicle shudders when lightly accelerating after an upshift around the following speeds: 26, 36, and 44 mph. Production changes to the torque converter have been made to fix this.
Production change VIN: JTHBJ46G # 82196161
The Repair: Replace the torque converter
Comment: Looks like Toyota has ferreted out and fixed the last of the U660E transmission problems. Kudos to them. Unfortunately, my dealer keeps telling me my car is "operating as designed", even though the shop foreman was able to reproduce the problem. Note that this "shudder" feels" much like a shift flare, but the tach doesn't spike like it does for the flare. It feels like a power sag and "thunk". Any brave souls up for seeing whether any dealers out there can replace a torque converter w/o scratching/breaking something or forgetting to put everything back correctly? This is a more complex job than a transmission replacement - one must remove the transmission, then separate the transmission and torque converter pieces.
Old 05-21-08, 07:03 PM
  #75
YotaCarFan
YotaCarFan's Avatar
Default L-BO001-08: Center console bin opens too easily
Issue: Pressing the release button on the center armrest console actually opens the console lid.
The repair: Replace the button mechanism with one having a stronger spring that's harder to push.
Comment: This one's for those folks who a frustrated because when they lean their elbow/arm over the button, the door inadvertently pops open.
Quick Reply: List of current ES350 TSIBs
