trac off light?
You need this part: Denso part number 234-4137 $50 bucks on Amazon
FYI This O2 sensor is for the two upstream sensors on your ES (assuming it's a non-California emissions car. If it's a CA car you'll need a Air Fuel ratio sensor.). Your error code P0136 is for the downstream sensor. Hence you need the downstream sensor I indicated on the previous post.
Max Power
08-19-09 05:51 AM
