UGHHH, VSC CEL lights are on
Old 01-12-11, 04:41 AM
D-Boi
D-Boi's Avatar
Default UGHHH, VSC CEL lights are on
So i came home today, and wanted to clear the snow of the driveway so i decided to move the ES, however the car was idling terribly rough and the VSC and CEL light is on. I dont think the CEL is flashing, i think it was solid. The car also runs really rough, does this sound like a knock sensor? Any ideas would be appreciated. Time to go sleep nightshift suckssssss.
Old 01-12-11, 01:52 PM
Bumbobee
Bumbobee's Avatar
My parking brake light is on most of the time now. It suddenly started to turn on when the temperature started to drop at the start of this winter season. I have no clue what it could be, any ideas?
I also have my rear light display light on in the dash, but apperently that's because the aftermarket bulb I used doesn't have the same voltage flow as the original OEM ones...
Old 01-12-11, 04:55 PM
D-Boi
D-Boi's Avatar
Are You serious??
Anyways i went and pulled the codes today and 3 of them came up.
0300, 0302, 0303
0300
Random cylinder misfire detected
Large vacuum leak
Fuel system concern
Ignition system concern
Engine mechanical condition
0302
Cylinder 2 misfire detected
Large vacuum leak
Fuel system concern
0303
Cylinder 3 misfire detected
Large vacuum leak
Fuel system concern
So to my knowledge, the culprit isnt an o2 sensor or a knock sensor.
Another main issue is that it will not go into 4th gear, darned thing is revving at 25 hundred at 40 miles per hour.
Any ideas my way would be greatly appreciated, im trying to figure this out on my own with your ladies and gents help, as i dont feel like taking it in anywhere. I want to do the manly thing and fix it myself lol.
Old 01-16-11, 11:22 AM
D-Boi
D-Boi's Avatar
any idears folks still havent gotten around to fixin this thing
Old 01-16-11, 11:29 AM
01ES300NYC
01ES300NYC's Avatar
could be ur ignition coils
Old 01-16-11, 11:30 AM
01ES300NYC
01ES300NYC's Avatar
have u changed ur spark plugs recently?
Old 01-17-11, 01:06 PM
D-Boi
D-Boi's Avatar
^^^ i was thinking that, i bought the car with 122k on it and it has 126k on it now and no i havent changed them and i didnt see anything in the service records saying that they were done. But why pop up out of nowhere though thats what im wondering.
Old 01-17-11, 03:57 PM
ASG14
ASG14's Avatar
The not goign into 4th seems like a seperate issue.
Cyl 2 and 3 are on different banks (diff sides of the engine), so it is liekly a big thing that happened. IF your plugs do have 126k miles on them, a little problem can turn into a big one like this.
Check the Intake Hose to see if it's split anywhere. It's also possible the MAF sensor can be dirty an not correctly reading the air causing a misfire. Thats an easy job to clean one. You just need Electronics Cleaner.
Old 01-17-11, 05:13 PM
D-Boi
D-Boi's Avatar
Well i just finished installing all 6 plugs, and the back ones were not fun at all. However its still the same, the car runs the same. i can honestly say i love my GS, owned 3 of them drove 200k miles between the 3 of them and never had any issues.
This car has been very well maintained, i just checked my records and the plugs had been changed at 90k with denso iridiums. I bought it from the lexus dealer here and i have every record for the car since new. Charcoal canister has been replaced at 90k so that rules that out as well.
gymraeg
07-14-19 05:36 PM
dealerGM
06-08-18 09:26 AM
tyson rust
03-27-18 07:22 PM
Jeckel30
GX - 1st Gen (2004-2009)
05-29-17 03:25 PM
HERBos
03-02-09 04:58 PM
Quick Reply: UGHHH, VSC CEL lights are on
