Headlight problem
Headlight problem
Hello all,
I have a 2000 es 300 & my passenger side headlight went out not too long ago. So I bought a new bulb, put it in, tried it & it didnt work. So i tried that bulb on the driver's side & it worked fine. I checked the fuses under the hood & those look fine. Anyone have an idea of what it could be? Relay, short? Any help is appreciated, thanks.
Check the pigtail for corrosion and clean it if if necessary. Youll need to get a wiring diagram and a 12 volt test light to trace the wiring. Did you physically test the fuse?, meaning do you have power on both sides? Sometimes you cant tell just by looking at it. Either way; you need to check the pigtail and the wiring. Does the hi beam work?
fastturbo
06-28-11 08:36 PM
