New Product PREORDER: Zero Deflection Track-Grade Spherical LCA Mounts.
We developed these a while back and with the advent of more track enthused IS-F's and RCF's we decided to make a product for those interested. These were initially tested on the N1 Racing IS250 that we campaigned at the 25hrs of Thunderhill. This was alongside Lexus corporate in the CCSR making the final test of the RC-F's 2UR motor and is an extreme test environment to say the least. We are putting them out for preorder and we can build them on demand or if there is adequate interest we can have the cups made in a production environment. We have been testing these on our IS-F with our new 15" front brake kit and it provides a nice improvement over our already proven progressive support bushing options.
http://shopfigs.com/v1/index.php?rou...product_id=318
First, we refined the Rear LCA mount for the IS RC and GS with a progressive polyurethane mount from SuperPro for performance street driving and tire saving. Now we release our uncompromised track performance solution that has been tested in the 25hr endurance race at Thunderhill on the N1 Racing IS250 Lexus factory sponsored car. This is the same race Lexus did final testing on the UR engine used in the RC-F. This system provides precise control under braking and acceleration and is especially designed for use with the extreme loads of R-comp tires and larger brakes like our 15" front BBK. With complete fore and aft rigidity, this zero deflection mount is a must for all track going cars looking to improve driver skill and reaction times while also allowing caster offset for enhanced steer in control.
PREORDER: EXPECTED TO SHIP MID-LATE SEPT.
ZDS: Zero Deflection System
-Solidly mounts the front LCA in compression and rebound under heavy loading.
-Allows caster offset adjustment via spacers for sharper steering initiation. Couple with our #1 bushings to reduce stress on the #1 arm mount.
-The most precise and responsive suspension motion available
The Components:
-Precision machined Bearing cup to utilize factory mounts and to align thrust load accordingly.
-Massive FK Bearing Precision 3P spherical bearings with PTFE liners.
-Stainless steel mount spacers with caster offset adjustment.
The Components:
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
New Product FIGS High Performance PolyElast UR Motor Mount
FIGS
CL Vendor Products for IS-F
20
01-03-21 07:57 PM
FIGS
13
04-06-16 08:13 AM
DaveGS4
12-15-13 10:21 AM
