Big Power on a Budget: Dan's NA-T SC
#107
The harness was built by my friend Chad Sommer @ Mayhem Garage in Concord, NC. Here is their facebook page: https://www.facebook.com/mayhemgargae/?fref=ts
I wish i could give you an accurate price, my assumption would be over $2000. Also, absolutely no clue on time frame either. As I said I waited over 10 weeks for mine, but I was also the guinea pig considering it was the first he's built.
#108
Here are a couple quick instagram videos of it running.
https://www.instagram.com/p/_AuSgOPTUk/
https://www.instagram.com/p/_QEewJPTcY/
#109
Since I took those videos the car has pretty much been at a stand still. I ran into some wiring issues with the gauge cluster and the 02 sensor readings and havent really done much in terms of trying to resolve the problems as I have been getting ready to move. Im planning on dropping the car off with a different friend of mine to have the last few details attended to while I move and get my new work space setup. In the mean time Im going to store the car at work and while its there Im going to fab up the rest of the exhaust and give it an alignment.
#110
Geez, pay to play right? I see the only real benefit to most of us is stripping out all the extra BS that we remove or delete and save weight and clutter. Otherwise it only makes sense for track cars to trash the car and then transplant the motor with ease into another body.
You're pretty much right on point there. The big benefits of going milspec are durability, flexibility, and weight reduction. Also, the Tefzel wire is silver coated copper, which has better conductive properties than that of an OE style harness's GXL wire. With that said, is the added cost vs. benefit justifiable for the vast majority of budget minded car enthusiasts?.... I don't really think so.
#111
Shielding
Don't get me wrong: the harness looks great. My concern is in your best interest.
Was shielding used for the knock, cam, and crank sensors? The OEM harness has a Faraday cage around those signals to suppress noise.
Thanks,
-scott
Thanks,
-scott
#112
Scott,
Here is the best picture I could find. The shielded wires are at the core of the harness.
#114
Indeed it does matter. All standalone ecus have a timing sync feature of some sort, all you do is lock the timing on the ecu and use the dizzy adjustment to dial it in with a timing light. Not hard to do at all.
bocahoo
GS F (2016-present)
15
06-13-18 09:56 PM
