Ongoing Build..and SC300FIVESPD One Day Gte swap Merged threads
dang! nice find! definitely bookmarking this..something very useful. ive always wanted one of these..but thought i had to use the stock sc one..nice to know the others work well too! now just to reverify my garage works with that garage opener..definitely beats the big giant remote i have =)
The home-links support regular and rolling code garages. Mine is a genie rolling code and works great, I really looked forward and did this Mod because my opener was making me very mad, kept getting batteries for the thing and this way its sleek, OEM and works alot better.
Registered User
OH man! I love this thing.Just finished putting it together and the results are amazing! I started a cut along the top part of the visor then slowly pull it apart and the seam will open. find where you like it mounted, there isn't alot of space so where i mounted it was just enough. Place the transmitter box on the visor foam and trace it with something. make sure it not backwards, double check it, you don't want to have to buy a new visor. then just cut and fit the transmitter inside the visor foam. Then i sewed it up with a needle and transparent plastic thread. if done right it would look almost factory.
GOOD LUCK, any questions or comments please ask.
^ I'm very sure you were!... NOT LOLOLOL
TO PROGRAM!:
-You hold 2 outside buttons for 45 seconds it resets everything.
-hold button you wanna program while holding garage door remote 2 inches away from it.
-when it blinks faster you let go every thing.
-if you have rolling code after that you press the learning button on the garage door motor in the garage and then press the home link button you just programmed 1-3 times when garage door closes you are good to go!
TO PROGRAM!:
Painted wood trim results!!
So the other day i was looking at my wood... trim and i was thinking wow that makes the inside of my car look OLD. so i decided to roll to the nearest kragen and see what types of paint i could buy and paint my trim with. i am very happy with the way my trim looks now. what do you guys think?
