Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Remove harden brake dust
Old 08-09-14, 07:14 AM
E350h
E350h's Avatar
Default Remove harden brake dust
I just bought a set of isf wheels they have harden brake dust on them. How do I remove without damaging the paint or clear coat. Anyone have this issue
Old 08-09-14, 09:51 PM
Jetfire
Royale with cheese
Jetfire's Avatar
have you tried normal soap and brush yet? next step would be a sonax or iron x on the wheels. Let it dwell and dissolve the deposits.
Old 08-10-14, 07:18 AM
E350h
E350h's Avatar
I've tried soap n a brush but still nothing I am goin to buy sonax next but they don't sell it at my local auto zone
Old 08-10-14, 11:09 AM
VTsuckah
VTsuckah's Avatar
You've got to buy sonax at websites such as autogeek or detailers domain, both of which are vendors on this forum. Make sure you buy some iron x. It is some great stuff and can be used on your paint as well.
Old 08-10-14, 07:25 PM
sydtoosic
sydtoosic's Avatar
Try the iron x first, a quality wheel brush and some elbow grease will do the trick. The Sonax may not be strong enough if the brake dust is as hard as you say. Seal your wheels when you're done.
Old 08-11-14, 05:03 AM
E350h
E350h's Avatar
Ok I will try that but what do you mean by seal your wheel
Old 08-11-14, 10:16 AM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
As already mentioned, CarPro IronX and Sonax Wheel Cleaner Plus may be great options for removing the build up crud on these wheels. If the buildup is that severe, it may take some time, and many rounds of cleaning, so do not expect it to be as easy as spray on, wipe off. Routine maintenance and protection of wheels is crucial, and clearly these wheels must have been neglected. Hopefully you can bring them back to life.
As far as sealing you wheels... a wheel sealant will help to provide a layer of protection between your wheel and the elements. This sealant helps to make routine cleaning easier and will help your wheels look cleaner for longer periods of time. This video shows my wheels that have been sealed wtih CarPro Hydro2. You will notice that water beads up and is repelled by the wheels due to the hydrophobic properties of the sealant. This product typically lasts 1-2 months on wheels, and it can also be used on paint, glass, plastic, metal, etc.
Proper protection for your paint is also critical. This video shows my vehicle, which has been coated with a premium ceramic paint coating, easily repelling water and dirt.
My hood was coated with CQuartz Finest 12 months ago for testing purposes when I became an authorized installer for this product. In this video, the vehicle is dirty and has not been washed in approximately 1 month (yes, one month ). You'll notice the car still looks quite good for not being washed in such a long period of time, and the protection is still evident despite the layer of dirt on the paint.
Hope that helps.
-Zach
Old 08-16-14, 09:18 PM
Pkp1903
Pkp1903's Avatar
I've had great success with Sonax Full Effect wheel cleaner. If they're really dirty you're gonna have to use a brush. Get yourself a boar's hair brush and you won't have to worry about scratching them in the process.
Old 08-17-14, 03:52 PM
PondScum
PondScum's Avatar
He wrote that he needs something strong. Full Effect isn't even Sonax's strongest wheel cleaner. Sonax Wheel Cleaner Plus is 30% stronger than their Wheel Cleaner Full Effect.
Old 08-17-14, 08:18 PM
Pkp1903
Pkp1903's Avatar
If I'm not mistaken he was asking for advice and I informed him of what I have tried and has worked well for me. I haven't tried your superb formula or technique so I wouldn't be able to recommend it, perhaps you should just be made the detailing mod.
Old 10-02-14, 10:20 PM
12lexusisf
12lexusisf's Avatar
Some tar remover might help
Old 10-03-14, 05:26 PM
Nidimob1
Nidimob1's Avatar
Try clay magic that has worked for me in the past
Old 10-07-14, 06:02 PM
xtr3me
xtr3me's Avatar
Like the majority of members recommended.... Iron X
In the pics below, the driver of the Honda is a female and loves a curb as can be seen in photo. These wheels had hardened brake dust and required two treatments using a brush after letting product dwell for a few minutes, then sprayed with a pressure washer. Not perfect, but just minor touch-up remaining..
If you don't have a pressure washer and are using a garden hose only, additional treatments may be required to achieve desired results as mentioned earlier
Photo of neglected wheels from a Chevy 2500. Sprayed iron-x on wheels, let dwell and then scrubbed with a brush, next rinsed off with a water hose..
Old 10-07-14, 10:04 PM
jw669
jw669's Avatar
Clay bar + tarminator as lube, followed by chemical guys metal shine worked very well on these
Old 10-22-14, 11:56 PM
1WILLY1
1WILLY1's Avatar
I recently repaired some leather seats for an auto detailer here in Toronto and he told me there are cheap alternatives to almost every product out there.
In terms of these wheel cleaners he told me they are basically a diluted acid, and he sayd he has the same or better results with 'swimming pool cleaner' which is also an acid and can be bought for pennies a gallon.
baconRx
14
06-04-19 06:03 AM
Madmax0609
05-09-19 04:56 PM
CouveGS
12-13-18 07:21 PM
ATLHeel350
RC F (2015-present)
02-22-17 05:54 PM
dsg03svt
IS F (2008-2014)
34
04-07-11 07:20 AM
Quick Reply: Remove harden brake dust
