Clay and light compound on clear bra ??
After 2 months with my new clear film on the car, the hood is now stained with a residu (like sap) that is embedded in the film, do your guys know if the film can be clayed and compound, it is Ventureshield ?
thanks
thanks
You can definitely clay it, but you shouldn't need to compound it at all.
When claying the clear bra, make sure to use a lot of lubricant, although the clear bra is very durable to things like rock strikes, it is soft enough that you can scuff and mar the finish if you aren't careful when claying it.
As for polishing it, you can actually use a light hand polish with something like the Einszett Paint Polish, or even a light polish like Menzerna Super Finish or Power Finish.
http://www.glisteningperfectionstore...00mL%2C/Detail
http://www.glisteningperfectionstore...-Finish/Detail
http://www.glisteningperfectionstore...32oz%2C/Detail
Just apply any of the polishes using a Microfiber Pad with moderate pressure and it should be able to lessen any hazing or marring that you have on your clear bra.
5% Club. Killing it!!!
Good to know..
Here's a FINE Grade clay we'd recommend on clear film:
http://www.glisteningperfectionstore...cant%2C/Detail
I'm starting to regret the Ventureshield clear bra, it is very clear that is nice, but it can scratch very easily and it doesn't have a clear coat to repair all the minor blemishes. I will start claying the car in 2 weeks since it has some ruffness on it, but i'm afraid for the clear bra since it makes like 50% on my car.
I have the Meguiar clay bar kit, it that ok for the clear ? Of course, i will go lighty and use alot of lube.
thank you.
PS: i've heard that applying some heat on the clear can correct some small marks, is that true ?
thank you.
Ventureshield is three layers with a clear top layer. Mine is going on 4 years old, not garage keep and this year will be the first time it will be clayed only because I'm doing the rest of the car. Totally satisfied!
Koz
Koz
No, I don't play soccer!
What about using Plexol or Starbrite on the clear bra? I read about some people using it in here. I plan on waxing in the next few weeks when the pollen finally breaks and then claying in the fall before winter sets in. Surface overall is still pretty smooth.
So you did clay the clear film with good results ? any tips to a good job. My car is also in a need for a clay. Did you polish the whole car after to remove all the small scruff marks from the clay ?
Koz
I've tried claying with the Meguiar clay kit and i look not harmful to the bra. Bugs stains are not getting off though, it looks embedded, what do your guys suggest ?
