Water Spots
Water Spots
What is the easiest way to remove water spots off of the paint and the windows? I am talking about the water spots that dont come off with a general wash or clay bar. Let me know.
thanks
thanks
Ya i know a buffer does. But there has to be some safe easy chemical that does. I know what you mean about rubbing them off. I am talking about a different car. This car gets hit by water every morning and the sun bakes the spots right in.
haha. Alright you guys thanks but i actually wash cars for money with a friend we kind of have a business... And i need advice on a way to remove them. when somebody asks you to detail a car you have to get rid of the water spots. Once those are gone the clay bar and wax do the rest.
If you are going to detail the car anyway you can remove them with an abrasive polish and a PC or rotary.
First of all, your car's finish has to be in good shape with a minimum of paint oxidation. Like new or recently waxed. A leaf blower packs 220+mph windspeeds, and blows off all the water beads that cause carwashing water spots. If you do use one, make certain it is new, or unwanted residue could damage your finish. I use one all the time - got the idea from Acura forums, and it does a great job. After fifteen minutes of "noisy" use, your car will look showroom ready, albeit with your ears ringing for a while.
All-Brite and MX-7 have worked for my business so far. All-Brite is an "acid-like" solvent and MX-7 is a liquid that both work with a little pressure and rubbing.
If you don't have access to these, start with a light polish, then move up to a more aggressive swirl remover or compound after that. Always start with the least aggressive approach when using polishes/compounds.
Good luck
Good luck
dubsonlexus
Mr Clean Magic Eraser. Takes a few seconds per window. But don't ever, EVER, use it on the paint.
If it doesn't work, then try soaking it in vinegar first. That almost always works on windows.
just finished detailing my car today had water spots that have been on my hood for the past 2 months I tried Scratch X the stuff is amazing couldn't be more satisfied just need a little elbow grease
