Power liftgate problems
My mother-in-law mentioned to me last night that she's having a problem with her out of warranty '07 RX350 when trying to open the power liftgate. My poor old '01 RX doesn't have that fancy option so I'm not familar with what to look at.
I haven't looked at it myself but here's what I know:
The problem has been going on for about a year. The lliftgate goes up about 2 inches, stops, & goes back down. Over the year it's gotten worse to the point now where it rarely works (but it will open all the way once in a while). Most of the time now she manually opens it. The closing operation works fine.
Does the power liftgate have any history of motor issues (and is replacing a DYI)? Not sure where to start investigating.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Since the hatch closes fine, I would therefore assume that something is impeding the smooth rise of the hatch. Possibly lubrication of the hinges or adjustment/replacement of the gas struts would solve the problem. (Lubrication to ease the effort of the motor; the struts to maintain original apparent 'weight' of the door.) Alternatively, maybe the 'sensor' could/should be adjusted to be less sensitive?
Good luck - and plse. let us know....
Had the same problem on my wife's 2005. I greased the hatch struts with silcone grease(same grease used for spark plug wires), where the stainless steel tube comes out. I also did the weatherstriping as well. Solved the problem.
Hopes this helps
Hopes this helps
cgolf4 (01-10-20)
Thanks for the replies. I'm going to try to get over and look at it in the next few days - I'll take some silicone and try that first. Just glad to hear that it may not be the motor.
I'll post the results. Thanks!
Just to close this one out...
Went over to her house tonight & first duplicated the problem - the power liftgate would barely go up an inch before stopping & going back down. Then I put silicone on both struts and it worked perfectly.
Thanks for the help!
Silicone lubricant? On the strut-stays?
I might just do that for maintenance purposes, but will use lithium grease instead.
While I might use white lithium grease spray on door hinges and such, I would not use that on the hood and hatch struts, IMHO. The silicone spray will help keep the gaskets from deteriorating and I have seen the white lithium grease dry out in the heat down here in FL.
Silicone it is.
I also use the 3M silicone spray on the window track trim. Spray into a rag and use that to wipe the trim pieces as well as the struts with an extra quick spray on the strut gasket where the piston enters the cartridge. A few manual close and open motions to work the silicone in a bit and you are ready to go.
Quick note that the dealer found it necessary to replace mine which hold up the hood on my RX330 while it was still under warranty. I had not complained, guess it was something they noticed while working on another problem I was having.
Help-Liftgate won't close as the lock is stuck in locked position
Moved furniture in my rx350, 2009 and couldn't close the hatch. Locking mechanism then locked up with the hatch in the open position. As lock itself is in the closed position, I cannot even manually close the rear hatch. I checked fuses, pushed the glove box off/on button, removed the hatch emergency release cover and tried manually pressing the release...all to no avail. How do I fix this. None of the switches (remote, driver's switch, hatch switch) seem to have any power. Any ideas????
Initialize it?? How???
2010 Lexus rx350
Hi can someone give me tips on 2010 Lexus rx350 trunk not open? I tried to replace gate hatch but still not working, still beeping but not clicking or open? I appreciate for ur commend , big thanks to all
