Passenger front window will not go up.
Old 05-19-14, 08:11 AM
anon1m0us
anon1m0us's Avatar
Smile Passenger front window will not go up.
All,
All my windows work, except my front passenger side window. It will go down, but not up from the driver side switch. It works from the passenger side.
I did NOT replace my battery or lose power. It started when I was driving and wanted the window half way down, but it kept going fully up or fully down. I finally got it to where I wanted it to be, but after that i could no longer bring it back all the way up. It can go all the way down, but no longer up.
Any ideas?
Old 05-19-14, 11:32 AM
chiph9
chiph9's Avatar
Pretty sure the windows work over the CANBUS network, so there isn't an individual pair of wires to each window from the driver's panel. My guess is the switch on the driver's panel is bad.
How to test this? Easiest way would be to swap that module for a known-good one temporarily.
Chip H.
Old 05-20-14, 10:17 AM
anon1m0us
anon1m0us's Avatar
Chip H.
Where can I order a module? Is it expensive?
Old 05-20-14, 10:39 AM
islandbeef
islandbeef's Avatar
Old 05-20-14, 01:34 PM
chiph9
chiph9's Avatar
You can get them from Sewell. They aren't cheap, at $530 before the clublexus discount. Which is why I suggested you find another GX470 to swap the part first.
http://lexus.sewellparts.com/oem-cat...X470-2006.html
Chip H.
Old 05-20-14, 04:41 PM
anon1m0us
anon1m0us's Avatar
Chip H.
That Youtube is for soldering the controller. I need a simple, less invasive way to test the controller and a place to order a new one.
Old 05-21-14, 06:07 AM
chiph9
chiph9's Avatar
I didn't post the video - I posted the link to Sewell Lexus, where you can order the part.
But first, since it's expensive, why not find another GX owner near you that is willing to swap parts to test it out?
Why? Because there's usually no returns on electrical parts at the dealership.
Chip H.
Old 08-25-14, 10:06 AM
MikeI
MikeI's Avatar
Default Similar problem
I have a similar problem where all the power windows work from their own door switches but not from the driver’s door. The driver’s window works from the driver’s door. I did just have the car services and the battery was disconnected. I am not sure if the battery being disconnected is tied to the issue, but saw that is was mentioned in this thread earlier.
Any ideas?
Old 08-25-14, 10:18 AM
chiph9
chiph9's Avatar
Try resetting the window limit switches - here's the link:
https://www.clublexus.com/forums/gx-...-or-reset.html
Chip H.
TXFM
09-07-24 10:12 AM
justin1203
04-26-19 03:06 PM
geopig
ES - 5th Gen (2007-2012)
03-25-19 04:17 AM
bacardi
05-12-12 11:56 AM
omarston
Maintenance
06-17-09 09:20 AM
Quick Reply: Passenger front window will not go up.
