Ohlins coilovers
Ohlins coilovers
I ordered these through a contact in Japan and should take 2 weeks to make the complete kit. We'll see. I ordered them with 16 and 12 spring rates.
http://ohlins.czj.jp/auto/Item/BTO-USE20_DFV_HAL.html
That is an awesome coilover that i like the most. Did you order over a vendor in the US or directly through Ohlin inJapan ? Do you mind telling us how much is it in US dollar?
Thanks!
Thanks!
Based off the website and the current yen rate looks like they are going for around 3300.00. Shipping will be the killer on them because of weight and they will literally be shipped to the States.
I sold my KW on my F thinking I will get rid of it. Because its just collecting dust in the garage. I decided to keep it and now the Ohlins for the F is available. Very tempting.
So did they finally come out with an actual ISF specific setup? I know they (Ohlins and FIGS) stated the ISx50 setup would bolt up but it was not specific to handle the heavier ISF.
https://www.clublexus.com/forums/is-...r-the-isf.html
It looks like Ohlins Japan maybe be doing their own build to order setups. If you check the specs, they offer 12/10 spring rates for the is250 and is350 and 14/10 for the is-f. I followed FIGS suggestion and ordered mine with 16/12 spring rates.
FTWisF (03-15-22)
update us when you get them installed. I am curious to see if the increase in the front rate while leaving the rear the same will lead to more understeer under hard cornering
