Brake Pulls
Old 03-21-14, 08:46 PM
jcollis217
jcollis217's Avatar
Default Brake Pulls
I have 1997 Lexus LS 400. When I apply the brakes car pulls to the left. I just put on new calipers on the front left and right. Put on new pads on the front also. Can anyone tell me what the problem could be? Thanks
Old 03-21-14, 09:02 PM
RA40
Super Moderator
RA40's Avatar
Sounds like a sticking piston. Re-bleed the brakes to make sure all air is out of the system.
Old 03-22-14, 01:07 PM
sha4000
sha4000's Avatar
Why did you put new calipers on is my first question? How do the rotors look?
Old 03-22-14, 02:26 PM
Largefarva
Largefarva's Avatar
^Same question, was it fine before, or were the calipers supposed to fix the problem? If the latter then who diagnosed it as calipers? Could be collapsed flexline, stuck abs actuator, bad suspension bushing, etc....
Old 03-22-14, 02:39 PM
cobalt91
cobalt91's Avatar
How did the pins for the calipers look?
Old 03-22-14, 03:08 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
did you check tire pressure on the left side....
Old 03-24-14, 05:12 PM
jcollis217
jcollis217's Avatar
Default Brake Pull
Thanks for replys. The problem was the brake line on the passenger side and the inside sets of pistons on the caliper was stuck. Fluid from the master cylinder was coming to the top of line but, the bottom of the line was block. Again, thanks for replys
irouse
08-10-16 03:38 PM
vintagelex
07-15-14 11:32 AM
peelsSC300
Suspension and Brakes
16
12-19-11 03:27 PM
gridlock13
06-18-11 02:25 PM
LEXuriouss
13
07-13-07 07:53 AM
Quick Reply: Brake Pulls
