NaT questions
Only issue with removing the EGR system is the CEL that will be given. Its done to eliminate some of the BS vacuum lines that are under the hood and clean some of the air going into the intake tract. There are block off plates available online for the deleted EGR system, or if you have the means, you can make your own.
