transmission question
Old 09-14-13, 10:25 PM
Bass Mech
Bass Mech's Avatar
Default transmission question
so i was reading a post on another forum and someone mentioned something about the gear indicator showing say gear 4 in manual mode but the transmission may be in a different lower gear. and thin i realized something about my old 2007 IS 350 rwd i recall the transmission worked that way. it will not hold a gear you select. rather it just allows the transmission to shift normally up to the highest gear you select.
is this true about the new IS? or can you select a gear like a manual transmission and it will hold the gear you select, not shifting up or down until you tell it to or until you come to a stop.
does the 6 speed and 8 speed behave the same way or are there differences?
thanks!
Old 09-14-13, 11:41 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
The new IS holds the gear, the old models did not (save for the IS F).
Jeff
Old 09-15-13, 02:15 AM
jhs82
jhs82's Avatar
The new 8 speed holds the gear. Not the 6 speed.
Old 09-15-13, 08:56 AM
CtSFox
CtSFox's Avatar
A Lexus salesman told me recently that the 6 speed will hold the gear if activated from the shift lever, but not if regulated by the paddles. Was I given misinformation?
Old 09-15-13, 09:35 AM
dojoman
dojoman's Avatar
It will hold gear with 8 speed but it will downshift on its own if the speed decreases dramatically or come to a complete stop.
Old 09-15-13, 12:17 PM
jhs82
jhs82's Avatar
That's news to me. Try it out!
Old 09-15-13, 12:37 PM
CtSFox
CtSFox's Avatar
I will, when my car comes in around Thanksgiving! Until then, I'll have to drive my IS virtually through you guys (and gals).
Old 09-16-13, 08:13 AM
redcupr
redcupr's Avatar
The six speed will hold whatever gear you select in Manual Mode whether selected from the paddles or the shift lever. And as dojoman mentioned, it will downshift as you slow down so the engine doesn't bog down.
Old 09-17-13, 12:26 AM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
I've driven both, and both had manual mode that held the gear.
Jeff
GaryJG
01-21-20 07:28 AM
booga
Performance & Maintenance
09-07-18 02:24 PM
SIUHEN
04-13-09 07:51 PM
fordsvtmfl
Performance
18
11-04-08 09:09 AM
Quick Reply: transmission question
