20 ton press useful?
I am thinking of getting a press from harbor freight..
Does it work on the bushings replacements that our car has, press bushings out and put new ones in? Somehow I have noticed there are pressable and non-pressable version of the bushing sold?
one thing I am not sure about doing is the LCA bushing, by the time I separate the ball joint and put it back, the ball joint is probably in worse shape and I might as well buy a new LCA
I used a quality press at a buddys shop on my GS bushings and it was a life saver (the caster arms require a press for the new bushings), but i would warn you that they can be dangerous. especially if you are pressing an oddly shaped arm (like the GS caster arm), they become hard to stabilize on the press bed and will pop and jump with a ton of force (one arm flew about 5 feet in the air). That said they can be really useful, i have heard of people buying the cheap harbor freight press then welding the frame in addition to the bolts and even welding some reinforcement bars to the frame, this is the route i am going to go when i buy a press.
markdav801
01-17-18 10:56 AM
EUROJulian
Suspension and Brakes
82
05-31-04 12:55 PM
