Engine Oil Level Low Warning
Hi guys,
I just got the warning "Engine Oil Level Low", pulled the dipstick out, check the oil level, it looks fine to me (the oil level is near the max level).
So not sure what happened here, maybe the sensor not working probably? I did my last service about 9k km ago.
Need some help from you guys, really appreciated.
Thanks alot
Thanks alot
The warning showed in the middle of the dashboard (where normally shows the temp/gear position etc) for a couple of seconds then disappeared. and only poped out when was on the highway.
so guessing it's the sensor?
OP did mention about if only show up on highway that's the reason i think oil oil pump. Anyway, double check to be sure is always good thing to do.
Are you sure you have the right dipstick? I know this seems odd, but I got this ALOT when dealing with Honda motors, since alot of theirs are visiably the same, but different length sticks (thus affecting the TRUE oil level).
I believe within the last month I've read about an actual oil-level sensor on the 2IS model; could be wrong, but it's what I'm remembering probably from a late-night web session.
Yes. I drove the LFA.
There is an oil level sensor on the ISx50, as well as an oil pressure sensor.
CrispyST3
Performance & Maintenance
12
10-13-11 05:20 AM
