2005 es330 front and rear caliper toque spec's
Hey guys i was doing a brake job on my es and was wanting to make sure i had the right torque spec's for the rear caliper bracket and slide and also the front caliper bracket and slides
Thanks
Thanks
Fronts: The bolts that go into the slide pins get 25 ft-lbs. The bolts for the caliper brackets get 79 ft-lbs.
Rears: The slide pin bolts get 25 ft-lbs. The bolts for the caliper brackets get 46 ft-lbs.
2005 Lexus ES330
Well while loosening the rear slide bolt and the Bolt snapped in side the hole and now we were so close and stumped. Really feeling bad. The caliper bracket bolt is stripped and don't know where to get the part .
Originally Posted by SGLexus
hey thanks LKF! So does that mean only the dealer can install it? I need to get that small part of the bolt out that stuck in when it stripped tomorrow.
Posted from ClubLexus.com App for Android
