SC- 1st Gen (1992-2000)
auto tranny console
Old 06-20-13, 09:07 AM
psychenry
psychenry's Avatar
Default auto tranny console
Can anyone tell me how to switch out the black plastic (center) auto tranny console on a "93 SC300?. I see there are electrical connections and a clip on each side.
Old 06-20-13, 09:15 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Yep, that's how. Pics are HERE
Old 06-20-13, 09:44 AM
10thMtnLex
10thMtnLex's Avatar
You'll have to remove the gear shift handle first (slide plastic collar down from the base of the shifter, remove 2 screws, slide shifter straight up) then the bezel plate can be popped out (4 clips, + 2 little 'locator pins near the ashtray) at that point you should be able to turn the bezel enough to get to the connectors for the switches. If the new bezel has switches would just be plug and play, if not you can carefully remove the switches from the old bezel (may need some small flat blade screwdrivers to release sme of the clips...) and install into the new.
Good luck!
Old 06-23-13, 04:07 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Get it out?
Old 06-24-13, 10:17 AM
psychenry
psychenry's Avatar
Default must return item
not yet. the one I received from e-bay was in worse shape than mine, but I think I found another one. thanks for asking.
Old 07-11-13, 12:37 AM
3jz
3jz's Avatar
Just pop it off too plugs power. Botton and shifter
jimmymac30
Performance & Maintenance
26
06-27-21 11:10 AM
booga
07-04-11 01:23 PM
bkempf7
11-02-10 12:08 PM
GSXRAWD
GS - 1st Gen (1993-1997)
02-11-04 02:05 PM
David Davis
05-13-01 03:49 PM
Quick Reply: auto tranny console
