Help! How to install harmonic balancer?? Special tool?
I've rented multiple tools to install the harmonic balancer but absolutely not a one fits.... I cannot find one, is there a special Toyota tool?
Help me out guys!
Thanks
Help me out guys!
Thanks
yes, it looks like a Y kinda. it has multiple holes and 2 oval slots so you can get the bolts on. you can rent it at auto zone or other places. you will also need a tool to hold the balancer secure while you torque the nut down.
I rented two of them, one from advance and one from Pepboys... both the pullers worked but they had the wrong size adapter. I will try Autozone but is there anyone that can link me to the right adapter? I'm at a loss.
Thanks
shouldn't be that hard to install the balancer...only special tool i used was a hammer and some PB blaster and slides right on. Bigger ***** was trying to remove it which i needed a special tool for. what sort of problems are you having exactly? are you lining up the key hole on the pulley with the crank key? something doesn't sound right...
