Help! How to install harmonic balancer?? Special tool?
Old 09-10-12, 05:07 PM
beenlookin
beenlookin's Avatar
Default Help! How to install harmonic balancer?? Special tool?
I've rented multiple tools to install the harmonic balancer but absolutely not a one fits.... I cannot find one, is there a special Toyota tool?
Help me out guys!
Thanks
Old 09-10-12, 05:57 PM
CDN-TEX
CDN-TEX's Avatar
yes, it looks like a Y kinda. it has multiple holes and 2 oval slots so you can get the bolts on. you can rent it at auto zone or other places. you will also need a tool to hold the balancer secure while you torque the nut down.
Old 09-11-12, 10:49 AM
beenlookin
beenlookin's Avatar
I rented two of them, one from advance and one from Pepboys... both the pullers worked but they had the wrong size adapter. I will try Autozone but is there anyone that can link me to the right adapter? I'm at a loss.
Thanks
Old 09-11-12, 01:12 PM
GTX580
GTX580's Avatar
i rented mine from auto zone, worked perfectly. its the claw type harmonic balancer, ill try to get the tool number for you if i roll by autozone later today.
Old 09-11-12, 02:56 PM
StiCk3
StiCk3's Avatar
shouldn't be that hard to install the balancer...only special tool i used was a hammer and some PB blaster and slides right on. Bigger ***** was trying to remove it which i needed a special tool for. what sort of problems are you having exactly? are you lining up the key hole on the pulley with the crank key? something doesn't sound right...
Gster
12-17-18 09:23 PM
davvv
10-10-17 08:52 PM
preston145
05-27-12 11:05 PM
marcyu
02-06-12 03:14 PM
KevsGS
CL of Southern California
09-15-04 03:19 PM
Quick Reply: Help! How to install harmonic balancer?? Special tool?
