Last edit by: IB Advertising
Browse all: Steering and Suspension
- How to Change Power Steering Fluid
Step by step instructions for do-it-yourself repairs
very angry...previous owner put power steering fluid
Right....so i went and bought Mobile 1 ATF fluid so i could do the turkey baster method to slowly change out the powerstreeing fluid.....From what i remember, ATF fluid goes from Red --> brown if it is over used.....
Now...when i open the cover of the power steering reservoir, i see a clear liquid which resembles power steering fluid NOT ATF fluid.
What do i do here? I don't think mixing the ATF and power steering fluid is a good idea...and if i take it to the dealer they will probably want to change the whole unit cause i didn't conform to blah blah blah...
Anybody have had this experience before or have any suggestions what i should do?
Oz
Oz
Are you doing power steering fluid or transmission fluid (ATF). If you opened the power steering reservoir and the fluid looks like power steering fluid why are you looking for ATF fluid? Are you using the manufacturer specified fluid for your power steering? If not, I wouldn't put ATF fluid in the power steering reservoir and get the proper stuff and drain and fill the reservoir.
Drain the system... turkey baster won't get all of it out.
These cars use ATF as the fluid for PS... which is stupid since mistakes like in the OP happen all the time.
If they put in power steering fluid they were wrong.
option 1, do the turkey baster method once a week for several weeks until you are satisfied most but not all the fluid has been replaced.
option 2, take your car to a non toyota/lexus service station and have them drain a fill / replace fluid. at least this way toyota lexus wont know about it in case there is an issue in the future.
lets be honest, if there is a problem, lexus will not send you fuild to a lab to test for proper type.
I took a spray bottle, and just un-screwed the nozzle part and put that part into the reservoir and squirted the ATF out into a bottle. Basically same thing as the turkey baster method, but this worked quicker, and got more fluid out.
great ideas, i will choose the full switch as a last resort as i'll have to overcome language barrier here in Hong Kong.
For the slow swap out (turkey baster / spray bottle) i still haven't seen anyone reply if mixing the ATF and power steering fluid will do any serious damage or gunk.?
I would go to Bobistheoilguy.com and post your question. Some of them are petro engineers that might be able to tell you about compatibility and mixing. Both atf and ps teering fluid are hydraulic fluids derived from petroleum so I think if you'd be fine doing the spray bottle method several times
In the past I have changed the power steering fluid myself by removing the return hose from the reservoir, aiming the hose into a gallon jug.. Then I get an assistant to start the car and begin to turn the wheel back and forth until the fluid stops squirting. Then I poor in a new bottle and have the assistant turn the wheel a couple more times to clean out any residual fluid. Turn off the car, put the hose back on and fill up the reservoir with new fluid. Then start the car and turn the wheel a few times to get air out of the line and then fill the reservoir again to the FULL line. This worked for me on my F150, TL, and X3. I haven't had to do it on the RX since the hybrid has electric power steering. The only downside to this method is it can get a little messy...But if you are careful you can do it without getting covered in fluid.
ToyotaLexus
RX - 1st Gen (1999-2003)
02-12-09 10:05 AM
