check engine/ trac off light are on
Old Oct 18, 2011 | 02:44 PM
mosquju70's Avatar
mosquju70
Default check engine/ trac off light are on
What is the fix to this issue on a 2001 es 300
Old Oct 18, 2011 | 03:02 PM
01LEXPL's Avatar
01LEXPL
did it occur to you to drive down to autozone to get the codes scanned?
Old Nov 6, 2011 | 05:34 PM
pronkie1's Avatar
pronkie1
Just went through this with my step son's 2000 ES 300.....Twice in two months....Was 02 sensors on the exhaust manifolds each time.....He only has 66k on it.....
Old Nov 6, 2011 | 06:54 PM
yeldogt's Avatar
yeldogt
lots of things can cause this.
And as the sensors age the heaters inside the fail -- so it is not simply a mater of the miles.
Old Nov 8, 2011 | 04:09 PM
Amadauss's Avatar
Amadauss
I have the same issue and the code is stating P0420 which is the bank1 02 sensor which is the one under the drivers seat from what I am told. Got the sensor and now need to replace but have heard various about location of it. Told to check out a post in the RX section that talks about taking the drivers seat out to make the change. Is this correct? Thanks.
Jordan95
Jan 22, 2018 07:23 PM
gomboy60
May 18, 2011 01:32 PM
Mylesf7
Nov 13, 2008 05:16 PM
royaladd
RX - 1st Gen (1999-2003)
15
Nov 5, 2008 11:48 AM
LEX300AM
12
Nov 3, 2008 07:28 AM
