Winter time: Do you guys warm up your engine?
Old 10-17-11, 12:45 AM
NyCrAzY
NyCrAzY's Avatar
Default Winter time: Do you guys warm up your engine?
Winter is around the corner for me in Northern Virginia and we get some moderate snow and cold temperates. Question is: is it a good idea to warm up the car or is it safe to drive right after starting up?
Old 10-17-11, 03:35 AM
hypervish
hypervish's Avatar
It's safe to warm the car up 30 sec and drive. You won't get overdrive, though until it reaches operating temperature.
Would I suggest only waiting 30 sec and driving? NO!
I'm old school and still warm up my RX 5 minutes, sometimes more. Call me the reason for pollution, I don't care. LOL
Old 10-17-11, 04:10 AM
Milan
Milan's Avatar
Not sure what the manual states for the RX but it advises against running the engine for warm up purposes on the LS. I get in and go but avoid moderate to heavy throttle before the temperature needle moves at least a third of the way away from the bottom.
Old 10-17-11, 08:59 AM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,103 Likes on 992 Posts
Best advice ever is to read the manual.
If your vehicle is missing one, check with the dealer or even call Lexus USA.
What does warm up mean:
Bring all lubricants to condition where they flow or provide lubrication.
With modern lubricants and oil weights this is not a problem. The transmission only gets heated up when you drive.
Bring the cabin temp to comfort zone.
This is what I see most owners try to do with remote starters etc. Keep in mind the pollution it creates [suv ... sarcasm]. Lets not make the situation worse.
Bring the engine to operating temp for optimal performance.
This is the only engineering reason to warm up. Interestingly, the engine and the other components down to tires warm up quicker when the vehicle is driven.
Net: It is best to start and wait a fraction of minute to get the pumps etc to circulate oil. [Just enough time to confirm every one is in belt and the all gauges show OK]. Then drive slowly and remain below 3krpm till the temp gauge indicates normal operating temperature.
Note: RX will keep you in low gear to help warm up quicker. So pay attention to the rpms.
Salim
Old 10-17-11, 09:21 AM
NyCrAzY
NyCrAzY's Avatar
The trick I do before driving is turning my heat on. At first, it'll have no fans on it until it warms up enough.
Old 10-17-11, 10:34 AM
salimshah
Forum Moderator
salimshah's Avatar
If any one is new to Lexus, the engineers have figured almost every-thing out for climate control. Leave the thing on auto and it does every thing .. recirc, fan speed etc. There are always exceptions but those guys have the system designed almost perfect.
Salim
Old 10-17-11, 04:31 PM
dbui
dbui's Avatar
my rx2001 I always warm up the engine for at lease 4-5mins in the cold day or else when I step on the gas for acceleration it making some kind of weir noise but once it warm up the noise go away?
Sybaritic
11-16-17 05:57 PM
MjThind
RX - 3rd Gen (2010-2015)
18
02-21-13 06:04 PM
ewingli
SC- 1st Gen (1992-2000)
08-14-12 12:23 PM
georgie39
10-30-10 07:05 AM
timoc42
Maintenance
24
01-25-04 11:33 AM
Quick Reply: Winter time: Do you guys warm up your engine?
