engine cover fasteners
Ok...I know this was posted in other places but could someone please let me know the part number for the plastic engine cover fasteners for an 03 Gx470.
thanks!
thanks!
There are several different sizes & types - could you identify which one(s) you need? I just ordered some replacement ones for my 2004 from Sewell - their website has the illustrations to show the different engine covers and fasteners, tho it took me some searching to find which figure to use, as some are treated as engine compartment, some as part of the front bumper, etc. Since I've just gone through this I'll help find the numbers if you can provide some more info of the locations you need.
90467-08217, covers radiator, airfilter and computer on drivers side. just ordered a handful, they always break when i take them out, no matter how careful i am, one or two crack.
Ok here is it.
Front above the Radiator - 12 nos - 90467-08217
Right side over the Air Filter - 5 nos - 90467-07117
Left side Driver Side - 4 nos - 90467-06155 ( Push button Type)
Hope this Helps
Hope this Helps
agent15 (07-06-19)
[QUOTE=mann777;6355166]Ok here is it.
Hope this Helps[/Q
06115 are the plastic screws that hold both covers against the firewall
07117 are the push buttons that are used for both covers, the numbers needed are correct
Hope this Helps[/Q
thats rite alan...thks for the correction...the only difficulty faced is when you intergrate the front Radiator Cover and the RH Side cover ( RH Side Cover over the Filter ) and lock the ones towards the corner of the headlamp, there is no support to push down the lock, you may have to give some support from down via the gaps available to hold down the locks.
