suspension noises
Old Mar 28, 2011 | 07:35 PM
reegeemon's Avatar
reegeemon
Angry suspension noises
need some help !
99 sc400
work completed (in order)
new pads (ebc green) & rotors (fronts drilled & slotted)
kyb shocks
4 upper shock mounts
sway bar links all 4
sway bar bushings f&r (rubber)
3 sepatare check by 3 different shops for ball joint wear (all said all were ok)
4 wheel bearings & seals
Daizen: rack bushings, complete front bushing kit, complete rear bushing kit, sway bar bushings,
(bearings and all bushings done @ same time - major pain to do !)
4 wheel alignment - completely went into specs
after all this still have a clunking in the front end when going over irregularities in road. seems lesser on freeways, but very noticable and irritating on city streets. doesnt seem to be much better than was before. shocks are much stiffer and might have actually caused to worsen.
at wits end trying to figure out, cause & cure. been all through suspension section and cant come up with fix. am i missing something ?
any help or ideas would be greatly appreciated.
Old Mar 28, 2011 | 08:14 PM
Luxor's Avatar
Luxor
Does the clunking still occur while having the foot on the brakes?
Old Mar 28, 2011 | 08:19 PM
Luxotic's Avatar
Luxotic
the repair shop should be able to reproduce the error on the lift ... have them place the car on the lift and put pressure on various areas with a manual lift until you can reproduce the noise
Old Mar 28, 2011 | 08:53 PM
reegeemon's Avatar
reegeemon
brakes on/off still the same. thought i found the problem in a previous post - but tried the brake loading yesterday - no real change.
did not have shop load suspension, however when had the ball joints checked, 3 separate shops said that all were good, based decision to change all bushings on arms w/good ball joints vs replace arms if had bad ball joints. i know that the bushings (new) are all good. seems to point to ball joints, but ...???
expected more harshness w/daizen bushings, are not horrible, like high durometer bushings would be, but now is considerably stiffer & much less "plush".
again have been all over suspension section looking for a clue but have found none.
Old Mar 28, 2011 | 09:33 PM
good2go's Avatar
good2go
How about your subframe mounting bolts?
https://www.clublexus.com/forums/sus...em-w-pics.html
Old Mar 29, 2011 | 10:12 AM
reegeemon's Avatar
reegeemon
will retorgue and advise
Old Mar 31, 2011 | 05:37 AM
reegeemon's Avatar
reegeemon
Unhappy still noisey
retorqued both xmembers - front was slightly loose (1/4 - 1/2 turn), rear tight.
made some difference, but still have some noiseness, not so much on highway, but mostly over irregularites in cement roads (slight height differences in cement slabs). no difference brakes on/off.
will welcome any ideas !
Old Apr 12, 2011 | 10:03 PM
reegeemon's Avatar
reegeemon
Default Noises !
someone out there MUST have some more ideas.
after all the work still noisy !
Old May 2, 2011 | 06:43 PM
gostsc's Avatar
gostsc
long shot but just thinking what parts tend to move and well I have had the inner fender wells rattle if the mounting bolts come loose. Also check your entire exhaust system for excessive play and movement. I see you put Daizen bushes in and I kinda recall on a old post about a washer/spacer on the LCA that if not re-installed would cause a rattle. But not sure if that was going to poly from rubber or vice versa. Curious as to your outcome.
Good Luck
Old May 2, 2011 | 08:21 PM
TechGreek's Avatar
TechGreek
Is it thunking popping etc
Old May 9, 2011 | 07:31 AM
reegeemon's Avatar
reegeemon
is "clunking" as though something is loose in suspension.
see first post all is new (except ball joints) or checked several times by several different people. went back and rechecked ball joints and are NOT loose/worn.
PERPLEXING !
Old May 9, 2011 | 07:37 AM
TechGreek's Avatar
TechGreek
After replacing my entire front end there was a clunking noise as well. I ended up having to retorque the UCA's to spec.
Also, check end links and sway bar bushings.
Old May 12, 2011 | 06:31 AM
reegeemon's Avatar
reegeemon
thanks for the reply.
am bumbfounded !!!
uca's are @ spec w/new daizen bushings, the end links & sway bushings (also daizen) are new
Old May 12, 2011 | 08:25 AM
BattleVer's Avatar
BattleVer
You sure its suspension? Maybe motor mounts or something else loose in the front.
Old May 16, 2011 | 09:27 AM
reegeemon's Avatar
reegeemon
am 99.9% sure is suspension.
