SC- 1st Gen (1992-2000)
1jz r154 or 2jzgte w58??
Old 12-25-10, 11:14 PM
TLsc300
TLsc300's Avatar
Default 1jz r154 or 2jzgte w58??
I really need ya help on this cause I'm undecided on which to get aha. So what ya think?
Old 12-25-10, 11:18 PM
tuterz
tuterz's Avatar
1jz r154 > 2jzge w58
Old 12-26-10, 01:05 AM
TLsc300
TLsc300's Avatar
I meant 2jzgte
Old 12-26-10, 02:19 AM
abounly
abounly's Avatar
w58 will not last long with the 2jzgte if your power hungry.
Old 12-26-10, 02:25 AM
VIPcarter
VIPcarter's Avatar
W58 is good for 350hp maybe a little more. If you plan to go all out 500+ then you might as well go R154
Old 12-26-10, 06:54 AM
megamax
megamax's Avatar
but isn't it better that you have the 2j powerplant?? and in an sc can you change the tranny without removing the engine?? or would it be easier to pull the whole damn thing?? and can you "*****-foot" 400whp on a w58??
Old 12-26-10, 07:11 AM
keesimo
keesimo's Avatar
1jzgte r154 or 2jzgte r154 or na-t r154, in the long run it will cost you more money with the trans, so save yaself time and money.
Old 12-26-10, 08:41 AM
stockhatch
stockhatch's Avatar
I agree with 1jz/R154. Sucks to worry about your trans every time you slam a gear and dump the clutch. I dont think the 2jz has enough advantage over the 1jz to worry about until you are at power levels that the R154 wont support anyways..
Old 12-26-10, 01:57 PM
megamax
megamax's Avatar
but "there is no replacement for displacment" right 3.0 vs 2.5
Old 12-27-10, 12:34 AM
VIPcarter
VIPcarter's Avatar
I wouldn't slam gears in a r154 but thats just me.
A BPU 2j on stock twins will put down 400+ which would cover my goal with an SC or MK3 supra and leave room for improvement. Thats why I like the idea of a 2j.
Old 12-27-10, 06:31 AM
stockhatch
stockhatch's Avatar
I guess you could say that. The question is, would 600-700hp be enough for you? If so, there is no reason a 1JZ wont get you there just as easily as a 2J. I would worry less about engine and more about tranny.
This is definitely true if you can find some USDM twins and fuel to support them.
Old 12-27-10, 07:15 AM
shern
shern's Avatar
Engine and tranny are mutually exclusive. Get whatever you can afford and deal within your constraints.
With that being said, your best bet is to first select the R154 transmission and then figure what you can afford, 1JZ or 2JZ. That simple. Both motors can get you into W58 implosion territory.
Old 12-27-10, 10:27 AM
VIPcarter
VIPcarter's Avatar
Find a MKIV owner thats going single, you could probably pick'em up for $100-$300 just depends.
Old 12-27-10, 11:37 AM
vietunit
vietunit's Avatar
W58 & serious power don't even belong in the same sentence.
search supraforums
Old 12-28-10, 09:09 PM
TLsc300
TLsc300's Avatar
sorry took me awhile to reply back cause my internet is off but yeah i know if your power hungry it wont last long but at least 300-400 im happy with it.
Quick Reply: 1jz r154 or 2jzgte w58??
