Ls 430 o2 sensor harness
Old 10-17-10, 12:41 PM
luey2010
luey2010's Avatar
Default Ls 430 o2 sensor harness
Hi this is my first post. Yesterday I had replaced my o2 sensor. (bank 1 sensor 1). Got the old one out with some struggles, but managed to get it loose. unfortunatley i pulled to hard on the retainer clip and pulled it off. Now i cant connect the new sensor to the harness. I need advice, please help. The clip that broke is not the o2 sensor its the other clip it connects to. thanks
Old 10-17-10, 07:15 PM
User 82021
User 82021's Avatar
you can buy the connectors from the dealer, they may tell you that you can only get it with the harness but it isnt true.
Old 10-17-10, 07:46 PM
m3nv
m3nv's Avatar
Like azcamber said, you can just order that part. Good luck!
Old 10-17-10, 08:42 PM
luey2010
luey2010's Avatar
ok so how do i connect them together? If my new 02 sensor is screwed into the manifold, and it just needs to plug into the connector? my problem is the connector has been pulled off of the wire harness. Does that mean I need the whole new harness? and how do I install it?
gebo
02-12-19 04:46 PM
msekanha
09-08-12 03:28 PM
Lewandoski
08-06-12 10:48 PM
Quick Reply: Ls 430 o2 sensor harness
