VSC ON and Off lights
Old 10-05-10, 06:05 AM
JasonBrods
JasonBrods's Avatar
Default VSC ON and Off lights
I have a 2003 SC430. For the last few months my VSC lights have been on. My mechanice told me it might be the computer because the code that is showing up is P0051 for the oxgen sensor on Bank 2 position#1. I figured that seeing it has over 80K to replace that O2 sensor. I found a universal fit where I had to splice in the wires, glad I chose that one because the wiring was hard to locate. Anyways... After replacing the O2 sensor I rechecked the codes after clearing them earlier, which also clear the VSC lights and there was nothing. A few days later the VSC lights were back on and the P0051 code was back. Could the computer be bad and it is stuck? Any ideas or suggestions? Also why is it that the VSC lights come on at the same time the trouble code P0051?
Old 10-05-10, 04:46 PM
m3nv
m3nv's Avatar
Did you replace all the 02 sensors? There are 4 on the SC
Old 10-06-10, 08:42 AM
JasonBrods
JasonBrods's Avatar
I only replaced the one that the code was showing for. I plugged in a ODBII code reader and it brought up trouble code P0051 the O2 sensor in bank 2 position 1. So I replaced it. How ever the code still won't go away.
Old 10-06-10, 02:37 PM
Harold57
Harold57's Avatar
Have you tried resetting the ECU?
Old 10-07-10, 06:12 AM
JasonBrods
JasonBrods's Avatar
I have cleared the codes if that is what you mean by resetting the ECU. Is there a different way to reset the ECU?
Old 10-08-10, 08:26 PM
WISLUGGO
WISLUGGO's Avatar
Two things:
1) the codes may go away with a "zero point" balance. Essentially, the dealer takes a few seconds and resets the sensors in the wheels. Do a search on VSC lights on, and you will find a few ways to fix it.
2) to reset the ECU you can just disconnect the negative terminal of the battery for am hour. Your settings will be lost but your ecu will also be reset.
Old 10-11-10, 08:18 AM
JasonBrods
JasonBrods's Avatar
OK... Lets start from the beginning... These lights started coming on when I had new tires installed at Firestone... Did they mess up a sensor? I tried disconnecting the battery for an hour, however the lights came back on short time later after driving it a bit. Could it be one of the sensors are actually bad? Or do the sensors just have to be recalibrated for the newer tires?
Old 10-11-10, 09:18 AM
VVTiBob
VVTiBob's Avatar
Here is the service bulletin on ZPC. I suspect you'll need to stop by a dealer and have them calibrate your car.
File Type: pdf
Old 10-12-10, 07:48 AM
JasonBrods
JasonBrods's Avatar
OK.. now I am totally frustrated.... I performed the zero point calibration according to the instructions... Lights did as they are supposed to, blinked really fast and so forth however. after starting the car, the lights came right on... Now what can I try? Can the yah sensors or the steering sensors be bad or is the O2 sensor code causing this?
Old 10-12-10, 08:21 AM
VVTiBob
VVTiBob's Avatar
have you tried the step is this thread: https://www.clublexus.com/forums/sc-...scangauge.html more specifically posts 10-12? This actually worked for me after I put new tires on and had an alignment done.
stevesturm
08-22-17 11:41 AM
andym666
07-29-17 11:16 AM
TexRud
08-18-15 12:01 PM
UpstateLex
03-23-11 06:01 PM
varcity64
09-14-06 08:02 AM
Quick Reply: VSC ON and Off lights
