a/c light blinking help
Old Oct 16, 2009 | 05:36 PM
divs's Avatar
divs
Default a/c light blinking help
hey guys wassup!! when i was driving my 2004 rx330 today the a/c light was blinking and the a/c was not cooling..can someone help? thanks you
Old Oct 16, 2009 | 08:00 PM
jfelbab's Avatar
jfelbab
Have your refrigerant level checked for starters.
Old Oct 17, 2009 | 07:39 AM
lexus114's Avatar
lexus114
by any chance,did you drive in heavy rain?
Old Oct 17, 2009 | 09:05 AM
RXSF's Avatar
RXSF
if you drove through a puddle, water may have entered the engine compartment where the belt is. It shuts down the AC as a precaution. usually restarting the car/turning off and on the AC again resets it.
Old Oct 19, 2009 | 09:57 AM
Ron.lexus's Avatar
Ron.lexus
Why dont u take your car to a mechanic. I think its not a big issue.
Old Jan 11, 2010 | 02:18 PM
boyboy9191's Avatar
boyboy9191
RXSF:
Is there any solution to stop the AC switching off when driving through a puddle?
Old Jan 11, 2010 | 02:56 PM
RJLEXUS96's Avatar
RJLEXUS96
Default A/c light flashing
Most likely the magnetic clutch relay failed. Ive done plenty of those on the older RX. Parts are around $70 and labor is $55. If the drive belts get wet the the car will shut down the a/c and you will see the light flash. All lexus cars have that.
Old Jan 11, 2010 | 03:26 PM
salimshah's Avatar
salimshah
25 Year Member
Originally Posted by boyboy9191
RXSF:
It has to do with some safety of the compressor. Details escape me, but all I care is that it normal.
Salim
RXSF's Avatar
RXSF
it is just a safety machanism. No big problem here. Just switch it back on after it switches off.
Old Jan 11, 2010 | 09:06 PM
mmlex1987's Avatar
mmlex1987
Wow,
I had no idea the described situation was a safety measure. I guess i just learned something new...
Old Jan 11, 2010 | 10:02 PM
salimshah's Avatar
salimshah
25 Year Member
Yep, safety of compressor and your pocket book.
Bonus points for who ever finds the reason behind it.
Salim
Old Jan 13, 2010 | 04:58 AM
RJLEXUS96's Avatar
RJLEXUS96
The reason behind it is if the drive belts get wet and start to slip, there are sensors on the pully that read this and shut off the compressor. If the belts happen to slip off, the the compressor locks up and the must be towed. Lexus
does this to prevent that from happening. Every Lexus car has this feature.
Also, if this a/c lights flashes when it is dry out then your Magnetic clutch relay is failing. It is a repair that costs under $200.
Jrocxzs
May 27, 2020 08:40 PM
tinnmanca
Jun 27, 2015 10:34 AM
whirlygig
Sep 6, 2009 07:22 AM
cheapsk8
Maintenance
Aug 12, 2003 06:44 PM
