IS-F Big Throttle by Think Design
Old Nov 20, 2009 | 05:05 PM
Galaxy 40's Avatar
Galaxy 40
Default IS-F Big Throttle by Think Design
What does this do?
Thanks
http://www.think-design.jp/exshopm.c...&kago=&dptype=
Old Nov 20, 2009 | 06:00 PM
chrisburke's Avatar
chrisburke
hmm void the warranty?? haha
Old Nov 20, 2009 | 06:17 PM
PHXF's Avatar
PHXF
lol
presumably bigger is going to let more air in...which would make more power if the oem throttle was the bottleneck.
Old Nov 20, 2009 | 06:19 PM
verals05's Avatar
verals05
There's another thread floating around here or on LexusF.com and I believe they claimed about a 5-10hp gain...
I'm sure its a pricey item too, but Think Design does make quality... you get what you pay for.
Old Nov 20, 2009 | 06:20 PM
ISFAIL's Avatar
ISFAIL
linky no worky
Old Nov 20, 2009 | 07:40 PM
ISFer's Avatar
ISFer
Originally Posted by ISFAIL
linky no worky
Link works here, and it's 68250 yen.......I'm guessing about $600 USD.
I wonder if it really is worth 5-10hp????
C.
Old Nov 21, 2009 | 07:42 PM
FIGS's Avatar
FIGS
The Maker
typically TB's will give better throttle response, more air into the plenum faster. HP may come at peak, but you may lose low end torque. For instance, I now have dyno proof of the wide open secondary intake path losing power over the stock 2-stage intake path in the low end. When will we get an ITBL setup...that would be the best by pushing the throttle plate closer to the valves
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old Nov 22, 2009 | 12:28 PM
K3RRYB's Avatar
K3RRYB
icode makes 2 available upgrade options. Since there are 2 manufacturers producing them this upgrade SHOULD make a difference. icode states +5 ps/5hp increase, with an upgraded intake and a more free flowing exhaust this should definitely yield more than 5 hp.
1.
2.
Old Nov 22, 2009 | 12:36 PM
K3RRYB's Avatar
K3RRYB
a little off topic but there's also a ecu reprogramming to sharpen the trans shift, map, throttle response, and speed limiter delete. +20hp
http://translate.google.com/translat...ial%26hs%3D14d
Old Nov 22, 2009 | 04:41 PM
Juanca's Avatar
Juanca
It makes sense, last year I reported that my times were slower when using the secondary intake wide open, at the 1/8 mile I lost 2 MPH and my times were about 0.2 seconds slower. This was done in the same night, back to back runs.
Bakewalk
IS F (2008-2014)
Nov 15, 2021 11:51 AM
rselby
IS F (2008-2014)
16
Feb 27, 2021 07:33 AM
Ltaboso
IS F (2008-2014)
Dec 24, 2015 03:25 PM
mikellucci
13
Jun 5, 2014 12:51 PM
الحمادي
IS F (2008-2014)
Oct 30, 2010 07:32 AM
