Difference in FSport Brakes for 250 and 350?
Old Nov 18, 2009 | 03:44 PM
OutCaster's Avatar
OutCaster
Default Difference in FSport Brakes for 250 and 350?
Hi,
Need your help.
What's the difference between fsport brakes for IS350 and IS250? The part numbers are different.
IS350 FSport
PTR09-53083-01
PTR09-53081-01
IS250 FSport
PTR09-53080-01
PTR09-53082-01
Thanks
Old Nov 18, 2009 | 04:19 PM
IZZO2FIZZO's Avatar
IZZO2FIZZO
http://fsport.com/#
Old Nov 18, 2009 | 05:13 PM
javyLSU's Avatar
javyLSU
2IS OG
They use different size pistons in the 250 and 350 calipers.
Javier
Old Nov 18, 2009 | 05:26 PM
GiantsFan's Avatar
GiantsFan
even though the pistons are smaller on the F-Sport IS250 version, is the physical size of the caliper the same as the IS350 version?
Old Nov 18, 2009 | 05:31 PM
javyLSU's Avatar
javyLSU
2IS OG
The caliper is the same part, it's an ST-60 StopTech caliper.
Javier
Old Nov 18, 2009 | 05:51 PM
GiantsFan's Avatar
GiantsFan
hmm ... well, since the discs, calipers, and the price are the same (ive always seen one price listed...), might as well buy the 350 version to get the bigger pistons (if you have a is250...)
Old Nov 18, 2009 | 06:06 PM
sean2sean's Avatar
sean2sean
you cant just buy a 350 caliper and fit it on a 250.
the piston size is different for a reason. stoptech test each vehicle with different size and determine which one works best. most likely the master cylinder is different between a 350 and 250.
Old Nov 18, 2009 | 07:15 PM
GiantsFan's Avatar
GiantsFan
actually yes you can. There are many members of this forum who own an IS250 and have bought the 350 brake kit for a BBK look for a cheaper price...
Old Nov 19, 2009 | 08:35 AM
OutCaster's Avatar
OutCaster
Could you put IS250 FSport Brakes on an IS350? Would there be any noticeable difference in performance?
Old Nov 19, 2009 | 09:23 AM
javyLSU's Avatar
javyLSU
2IS OG
Why would you put the 250 kit on the 350? Sure, it'll bolt up, but Stoptech took the time to engineer a specific application for use on the IS250, why not take advantage of that? There will be absolutely no performance benefit from doing this - on the contrary, you could actually be worsening your braking performance by not using the kit designed for your car.
Javier
Old Nov 19, 2009 | 09:32 AM
OutCaster's Avatar
OutCaster
Javier
understood, thanks.
Old Nov 20, 2009 | 05:52 AM
sean2sean's Avatar
sean2sean
If you want to use a 350 caliper on a 250 then its best to install a porportinal valve.....
Old Nov 20, 2009 | 07:39 AM
sean2sean's Avatar
sean2sean
alexlude
Jul 18, 2017 05:24 PM
stlgrym3
Aug 29, 2015 05:24 AM
Celledral
Oct 20, 2014 07:48 PM
Therealman
Jul 5, 2013 08:39 PM
lachuy85
Feb 21, 2011 01:36 PM
