performance throttle body
Old Nov 7, 2009 | 04:36 AM
sagarx's Avatar
sagarx
Default performance throttle body
i found bored out throttle bodies for the 1mzfe engine(says for the solara) i wonder if it will fit the es300's?? and would this be the answer to removing the dual throttle bodies on the 3rd g es's to a single or is there way much more to it.if i could mount it, & everything hoses,ect had a place to go that would be sweet but i have no clue any ideas,or am i stuck with dual throttle bodies for ever??
http://www.proflowdesign.com/tbtoy.htm
Old Nov 7, 2009 | 05:19 AM
Lexmex's Avatar
Lexmex
Anything that is single throttle body 1MZFE should be interchangeable with other 1MZFE engines. However, I'll take the dual thottle body on my RX300 any day to one of these. One thing I do wish was available (but is available for single throttle body 1MZFE) is a throttle body spacer. It's discussed frequently on www.solaraguy.com in their modifications subthread, but they don't make ones for dual. Some people give this a thumbs down, but I did see the result on my friend's Z06 where we actually put two throttle body spacers (and the throttle body was cool to the touch), one wasn't enough.
Old Nov 7, 2009 | 07:17 AM
sagarx's Avatar
sagarx
so my questions is can i change the duals to a single? also why would you take the duals to a single any day? if i bought an entire single throttle body would it hook up,bolt up & function right?
Old Nov 7, 2009 | 08:41 AM
ASG14's Avatar
ASG14
^ If you change from a dual to a single, you ALSO need to change the intake plenum, as they are designed differently.
Old Nov 7, 2009 | 11:34 AM
sagarx's Avatar
sagarx
ok 2 questions. 1. is it worth it? 2. do i get a intake plenum off a single throttle body es???
Old Nov 7, 2009 | 12:57 PM
Lexmex's Avatar
Lexmex
Personally, I'd rather take the dual, but the aftermarket/modification support is greater for the single. If ever manage to set up a ram air system like I've done with my RX300, that dual throttle body is nice to have in that case. So for me not, worth it it. Take a look at my thread here, https://www.clublexus.com/forums/rx3...ark-plugs.html (I don't really remove the entire throttle body out, but more separating it, but you can get an idea of what's inside.
Old Nov 7, 2009 | 06:32 PM
angmedic91's Avatar
angmedic91
Lexmex, wondering if you have a direct link in regards to the throttle body spacers thread on Solarguy.com. I did a search and a hundred and some pages show up.... thanks.
Old Nov 7, 2009 | 07:48 PM
Lexmex's Avatar
Lexmex
No, I wouldn't do that.
Just kidding
It's actually one for the Tacoma they discovered would fit on the Solara, and hence the 1MZFE. It only fits on single throttle bodies, not dual ones (which is why it won't work in my RX300).
http://www.solaraguy.com/viewtopic.php?t=26099
http://www.solaraguy.com/viewtopic.php?t=36400
http://www.solaraguy.com/viewtopic.php?t=28862
http://www.solaraguy.com/viewtopic.php?t=25765
Midias is a real cool character over there, nothing but my best regards to him
And here is a thread on one of those performance throttle bodies,
http://www.solaraguy.com/viewtopic.php?t=33424
Old Nov 9, 2009 | 02:00 PM
angmedic91's Avatar
angmedic91
Just kidding
Thank you very much for the links. I have a single throttle body, so Im hoping I can upgrade and increase my performance on my 1MZFE, again thanks bro.
Old Feb 12, 2010 | 11:42 AM
angmedic91's Avatar
angmedic91
I know this thread is a little old, but I did end up getting a rebored TB for my 98 ES. Proflow Design really communicated well with me, answered every question I had and sent over a nicely machined and powdercoated TB, it looked close to brand new. They installed a new larger chromed butterfly valve. I was very impressed. The installation took about two hours, spent time really cleaning out the Idle Control Valve, lots of carbon deposit. All in all, I am very pleased and there is more pep when you step on the gas, with all the extra engine upgrades I have, the car is a lot faster and sounds a lot better.
Old Dec 3, 2020 | 02:29 PM
TonyBlack's Avatar
TonyBlack
Can you link to the TB spacers for the ES? I had spacers on my 8th gen maxima, and they did work.
Old Dec 3, 2020 | 03:50 PM
Sargon's Avatar
Sargon
Faster: the air volume for the same throttle disc angle is higher.
In a stock engine the TB size is definitely not the limiting factor.
People see what they expect to see, especially if they paid for it. Spacers are faster with more of your wallet missing.
Rob200t
RC - 1st Gen (2015-present)
Jun 13, 2018 05:32 PM
rac74
RX - 1st Gen (1999-2003)
Jan 12, 2017 11:04 AM
NEbiker10
Mar 22, 2011 09:54 PM
