DIY: fender rolling thread and discussion
Old Nov 4, 2009 | 12:34 AM
ek9vboi's Avatar
ek9vboi
Originally Posted by rominl
sure! before you work on your rear fender maybe you can take some pics so people can compare what stock is like
From the dead!
Just did them in anticipation or new wheels soon. Actually I'm on some loaners for now, I'll post pictures up later but the new set up will be similar. Didn't take any pictures but its done. Did a good job I might say.
Old Nov 4, 2009 | 08:44 AM
rominl's Avatar
rominl
exclusive matchup
awesome man, can't wait to see your new wheels. seems like everything went well
Old Nov 5, 2009 | 12:40 AM
ek9vboi's Avatar
ek9vboi
Still have to work on the fronts, I am guessing for now all that's required is a heat gun but I need to find a fender roller.
Old Nov 5, 2009 | 08:29 AM
rominl's Avatar
rominl
exclusive matchup
hey some teaser pics will help!
Old Nov 5, 2009 | 01:00 PM
I8ABMR's Avatar
I8ABMR
I am excited to see what you picked and to see how well it fits. Congrats man. New wheels are always exciting. I just hate picking them. I always seem to stress the choice I make for weeks before I finally pull the trigger
Old Nov 5, 2009 | 05:41 PM
ek9vboi's Avatar
ek9vboi
Not exactly new, the ones I am on right now anyways. It's a temporary set, but boy do they ride nice and quiet! I'll have a teaser up but that will be it till I get the coilovers and lower the car more.
My actual set that is being ordered/made will be by MC3 wheels, that will be a shocker from the left field.
Old Nov 5, 2009 | 08:43 PM
I8ABMR's Avatar
I8ABMR
Speaking of quiet, I removed the Tanabe exhaust recently and I am loving it
Old Feb 9, 2010 | 01:21 PM
beez43's Avatar
beez43
as far as the rear fenders, did you guys shave it all the way down so that there is no little edge? Wouldnt that shave off the weld spots of the quarterpanels and you can potentially split them?
Old Feb 9, 2010 | 02:34 PM
rominl's Avatar
rominl
exclusive matchup
in my case, i shave it all the way. well maybe 1mm left. i don't know exactly where the weld point is, but i didn't encounter any problem.
Old Feb 9, 2010 | 05:39 PM
passnu2's Avatar
passnu2
^ Yea I probably have the same left on mine...
You can PM Gytis123 and he can tell you where the welds are and what to look out for. He may even have some pics from my car or others that he has done.
Old Feb 15, 2010 | 07:40 PM
beez43's Avatar
beez43
awesome and thanks guys for the input.. just had mines done and it looks clean.. however the fronts werent done because the guy couldnt figure out how to keep the lining there when the tabs are rolled in.. but now that i read the first post more carefully, ill attempt that myself since a friend has a heat gun... now i just need new rims..
Old Feb 15, 2010 | 11:00 PM
rominl's Avatar
rominl
exclusive matchup
glad it helps. but yes, the key is, put the lining behind the tab and roll things get very tight
Old Feb 16, 2010 | 12:26 PM
ek9vboi's Avatar
ek9vboi
I actually cut off that tab near the front fender, it was getting in the way of my rolling since it's toward the front that rubs. Now what to do with that bracket that holds the headlight in place... any ideas Henry??
Old Feb 16, 2010 | 02:37 PM
rominl's Avatar
rominl
exclusive matchup
lol dude, stop riding so low i am curious, in your case, without those tabs, how do you hold the lining in place? wouldn't it kind of left hanging a bit?
regarding the brackets, i suppose you mean the lining is completely worn off exposing the bracket? how often do you rub? i am not sure if i have a good solution for that case, if anything i think a relatively big metal plate around the area to basically smooth out the rubbing might be the only way to go?
Old Feb 18, 2010 | 01:47 PM
ek9vboi's Avatar
ek9vboi
I learned the hard way when I was rolling the fronts. At a certain point when rolling, the tab got in the way which sort of forced the fender roller to push/pull it out further. If I would have known, I would have bent the tab forward, away from the fender and then roll instead of rolling and then the tab pushing into the fender itself.
Riding low? All the wheels I've been on have had weak offsets. Maybe it's my tire selection and the width of the rim. No stretch, which in turn could be a reason. Also, keep in mind that I've been on DF210s all this time till recently. Now I'm around a 3" or so drop.
Might have to cut the bracket and relocate the bolt holding the bumper. I don't know how those guys with agressive offsets and chucky tires do it. Oh yeah, can't for get riding low.
