i put in my upper control arm bushings and my caster arm bushings iam not doing the lower control arm bushings. The ride is tighter and the brakeing is much improved its way more responive i have to get used to it. Overall iam happy do you guys think i should do a wheel alignment?
......u talking bout the front control arm bushing kit?? did this change your ride quality? i heard people switching back from this kit saying it rides rough
Did you forget what the first post said , i filled almost everything in there from alignments to cause of harshness.
Upgrading to 01 and up arms and ball joints is not a bad thing but you have to buy a matching set.
Does this mean you need to buy a matching set of control arms (lower #1 and #2), or a matching arm and ball joint? Also are the 01 and up arms all the same on the second generation GS? Finally what year (s) arms will fit on a 98 GS400? Thanks.
it applies to all lexus RWD cars.
Specifically the 98-05 GS in this post.
There are 2 kits available from TM engineering for 98-00 and 01-05 cars as the earlier ones had caster smaller arms and and bushings . For exact details check tm's site. It can be updated with newer 430 arms and ball joints but then you are paying for a new bushing unless you find used arms to press in the new bushings instead.
Thanks for the quick response. As a follow up....are the 01-05 newer arms all the same and why do you need to update both the arm and the ball joint if putting the newer arms on a 98-00 car? Why can't you just update the arm only?
i didnt do the alignment yet i orded the upper control arms (800 bucks) when i get them iam going to remove the control arm bushings and sell them with the lower arm bushing that i didnt use. I dont want to cut up the new arms. ill keep you up dated.
