front suspension fixes and facts
Old Oct 15, 2009 | 12:39 PM
  #46
GS4_Fiend's Avatar
GS4_Fiend
I changed my lower control arm now it rides stiffer but it's solid.
Old Oct 15, 2009 | 04:53 PM
  #47
Red Bully's Avatar
Red Bully
i put in my upper control arm bushings and my caster arm bushings iam not doing the lower control arm bushings. The ride is tighter and the brakeing is much improved its way more responive i have to get used to it. Overall iam happy do you guys think i should do a wheel alignment?
Old Oct 15, 2009 | 05:49 PM
  #48
GSteg's Avatar
GSteg
Yes you should do an alignment. Anytime you replace something like bushings, you need to have the car realigned.
Old Oct 15, 2009 | 09:32 PM
  #49
skperformance's Avatar
skperformance
Originally Posted by sakataj
......u talking bout the front control arm bushing kit?? did this change your ride quality? i heard people switching back from this kit saying it rides rough
Did you forget what the first post said , i filled almost everything in there from alignments to cause of harshness.
Old Oct 16, 2009 | 10:30 AM
  #50
sakataj's Avatar
sakataj
i guess so, i re-read it now, thanks
guess i'll buy these and add them to all my other bushings i need to do. i'll probably install ALL but the lower control arm bushings
Old Oct 16, 2009 | 11:25 AM
  #51
Red Bully's Avatar
Red Bully
will do thanks iam getting it done tommrow
Old Oct 20, 2009 | 09:40 AM
  #52
Och's Avatar
Och
Does this apply to all 2GS or just 98-00?
Old Oct 20, 2009 | 11:18 AM
  #53
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
DO you have an update RED BULLY..
Old Oct 21, 2009 | 06:10 PM
  #54
AZGS4's Avatar
AZGS4
Upgrading to 01 and up arms and ball joints is not a bad thing but you have to buy a matching set.
Does this mean you need to buy a matching set of control arms (lower #1 and #2), or a matching arm and ball joint? Also are the 01 and up arms all the same on the second generation GS? Finally what year (s) arms will fit on a 98 GS400? Thanks.
Old Oct 21, 2009 | 09:59 PM
  #55
skperformance
it applies to all lexus RWD cars.
Specifically the 98-05 GS in this post.
There are 2 kits available from TM engineering for 98-00 and 01-05 cars as the earlier ones had caster smaller arms and and bushings . For exact details check tm's site. It can be updated with newer 430 arms and ball joints but then you are paying for a new bushing unless you find used arms to press in the new bushings instead.
Old Oct 22, 2009 | 01:03 AM
  #56
Och's Avatar
Och
Can you please point out which one is the caster arm on this diagram?
Old Oct 22, 2009 | 05:47 AM
  #57
AZGS4's Avatar
AZGS4
The part labeled with 48068E (RH) and 48069A (LH) in that diagram is the caster arm.
Old Oct 22, 2009 | 05:52 AM
  #58
AZGS4's Avatar
AZGS4
Thanks for the quick response. As a follow up....are the 01-05 newer arms all the same and why do you need to update both the arm and the ball joint if putting the newer arms on a 98-00 car? Why can't you just update the arm only?
Old Oct 22, 2009 | 01:45 PM
  #59
skperformance
You did not read the first post , please read it again carefully to understand.
Old Oct 22, 2009 | 04:41 PM
  #60
Red Bully's Avatar
Red Bully
i didnt do the alignment yet i orded the upper control arms (800 bucks) when i get them iam going to remove the control arm bushings and sell them with the lower arm bushing that i didnt use. I dont want to cut up the new arms. ill keep you up dated.
