TSB AC003-07 HVAC evaporator drain replacement
Old 10-19-09, 07:03 PM
GS2006
GS2006's Avatar
Default TSB AC003-07 HVAC evaporator drain replacement
Anyone have this done? Any issues introduced by having this done? If you had smell, did it go away?
Old 10-19-09, 08:40 PM
steviej
steviej's Avatar
I thought this was a rerouting of the drain. Supposedly the GS has a different type of drain for the evaporator box, not as simple as the GS of earlier years. I was told this drain tube can pop off easily and the result is drainage into the cabin and under the carpet. The TSB I think is for a reconfigured drain that won't pop off or doesn't pop off so readily.
I don't think this alleviates the smell as bacterial and fungal growth still occurs in the close confines of the evaporator fins.
But if someone has access to the actual TSB, please post up a PDF copy.
steviej
Old 10-20-09, 06:45 AM
STP
STP's Avatar
Check my post # 2 from another thread.
https://www.clublexus.com/forums/gs-...et-carpet.html
Its very inconvenient during the repair phase. My car was in the dealer for at least 3 weeks. But my mold/mildew was also the worst they had ever seen.
As for the smell from the AC unit, thats two separate issues and areas in question. Steviej covered it with regards to the smell coming from the ac, and the link above covers the drain issue. BOTH have the same smells. Its mildew/mold that you're smelling.
While the TSB I had done took care of the wet carpet, the smell from the ac is still there. Haven't smelled it recently because of the weather and lack of AC use, but i'm sure once I run the ac again it will come back. I'll probably take care of it next summer.
Old 10-20-09, 08:25 AM
GS2006
GS2006's Avatar
Okay,
I foo bar’ed this a little:
They stated they replaced the A/C evaporator not the drain plug/packing listed in the TSB I included. They stated there is a TSB for replacing the AC evaporator. I’m waiting for the TSB number. They said the drain was in good shape and I do not think they replaced it. Not sure why they would not go ahead and replace a simple part since they have the dash and ac already out and it has a possibility of failing or getting clogged.
Old 10-20-09, 08:40 AM
GS2006
GS2006's Avatar
Here is the TSB AC003-07
https://www.clublexus.com/forums/att...ain-tsib-2.pdf
I could not find a GS removal of process, but here is on for the IS:
https://www.clublexus.com/forums/att...ac-removal.pdf
Not a light labor task.
The TSB the went by for replacing the evaporator was tsb 0011-09
Trying to find it.
JohnnyCake
05-20-20 06:11 PM
lserlohn
RX - 1st Gen (1999-2003)
02-22-11 09:30 PM
Ryan300
01-07-11 09:16 AM
swat1727
11-20-09 08:51 PM
deus85
09-05-07 10:08 PM
Quick Reply: TSB AC003-07 HVAC evaporator drain replacement
