front suspension fixes and facts
Old Oct 8, 2009 | 03:31 PM
  #31
GSteg's Avatar
GSteg
Stock ones aren't low quality I would say. More like undersized compared to the 01+
I have daizen but I think I'm going to switch it out with an 01+ stock arm.
Old Oct 8, 2009 | 04:15 PM
  #32
tmf2004's Avatar
tmf2004
5% Club. Killing it!!!
Originally Posted by pa06810
The best advise I found,on this forum, from skperformance I believe,Was to change out the caster bushings...99 GS 400...to Daizen. I have a 54,000 mile,stock 17s,never abused or winter driven. It always had that stupid little shake...65mph bla, bla. New tires, hunter road force, all the so called fixes. Made me not like my car, I changed out the caster bushings only, shake is gone, rides like a new car. Flawless! Not that hard to do,my local shop pressed in the bushings for me..$32. Thankyou! The stock bushings are low quality to say the least. It should be mandatory to change these before doing anything to the suspension. Factory bushings should be recalled! Thanks again
Lets get a petition going and send to Lexus headquarters.. Probably 90% of us have this issue including me.
Old Oct 8, 2009 | 09:34 PM
  #33
skperformance's Avatar
skperformance
A petition will not make a difference as it is now out of warr .
Upgrading to 01 and up arms and ball joints is not a bad thing but you have to buy a matching set.
GS4 fiend ,(Other thread aside ) look at the sway bar bushings as problem . The top hats usually only make noise under cold conditions when driving slowly over bumps. Also you can look at the top of the shock tower to see if the new ones where installed.
Also you can spray some silicone lube or rust proofing spray at the top hats to soften them and check to see if it improves the noise.
Old Oct 8, 2009 | 10:15 PM
  #34
GS4_Fiend's Avatar
GS4_Fiend
Thanks for the word of advice. Do appreciate it.
Old Oct 8, 2009 | 10:21 PM
  #35
GS4_Fiend's Avatar
GS4_Fiend
Forgot to mention. After installing the new lower ball joints and the No. 2 lower control arm. I do feel like the car is slightly lowered when I sit inside and the rides feels solid but a little harsher or stiff. Is that normal?
Old Oct 9, 2009 | 12:37 AM
  #36
skperformance
It only feels harsher because the wheels are staying in correct position so the rest of the suspension will transfer the forces back to the wheel since before it was sloppy and any pressure was absorbed.
Is it OEM parts and what wheel size do you have as that will change it also.
Old Oct 9, 2009 | 09:12 AM
  #37
GS4_Fiend's Avatar
GS4_Fiend
Oem parts. I got stock 17's
Old Oct 9, 2009 | 10:17 AM
  #38
tmf2004's Avatar
tmf2004
Man i cannot wait to do this.. I must say that my front end feels a little slopping as well and this creaking and popping noise when turning and backing out of driveway is getting old.. I only have new Ball joints and nothing else.. I'm sure the weight geometry is transferring somewhere.. I need to order this soon..
Old Oct 9, 2009 | 10:53 AM
  #39
sakataj's Avatar
sakataj
seriously....anyone have a part # to this kit?
Old Oct 9, 2009 | 12:26 PM
  #40
tmf2004's Avatar
tmf2004
U mean for the bushing kit? Check Sewells website.. Looks like there on backorder again..
Have to get from TM..
T
Old Oct 9, 2009 | 08:03 PM
  #41
skperformance
One other thing to note , the front tires will make a horrendous howling noise when it is really bad . It sounds like the bearings are dead but does not stop when going left and right like a bad bearing.
Why do you want a part number so badly , only one place has any in stock to sell you.
Old Oct 12, 2009 | 11:51 AM
  #42
sakataj's Avatar
sakataj
T
well if i knew WHICH bushing kit we were referring to i would do that
its the front control arm kit right?
Old Oct 13, 2009 | 11:16 PM
  #43
skperformance
Sak you have been on this site for more than a day , does daizen make any other kit that has the caster bushing?
So why would there be any separate kit for it.
You know what you need.
Old Oct 15, 2009 | 09:32 AM
  #44
tmf2004's Avatar
tmf2004
Yes... TM should have them.. Sewell is on back order again
Old Oct 15, 2009 | 12:07 PM
  #45
sakataj's Avatar
sakataj
no, i just joined today. only daizen kits i know of (i checked daizen's website and now know of the others) are the steering rack bushing which i have bought but not installed and their sway bar bushings which again i have bought but not installed
i wasnt sure which kit the caster bushing came in but after looking at the below list of all the kits im assuming......
Front Control Arm Bushing Kit (98-99)
Front Control Arm Bushing Kit (00-05)
Upgraded Sway Bar Set
OEM Sway Bar Bushing Kit
Steering Rack Bushing Kit
Rear Camber Correction Kit
......u talking bout the front control arm bushing kit?? did this change your ride quality? i heard people switching back from this kit saying it rides rough
sewell ALWAYS seems to be on backroder with daizen
