Sponsored by: CARiD
HID Lights Problem
Old Sep 29, 2009 | 03:02 PM
Neucorp's Avatar
Neucorp
Did you test with the multi-meter?
Old Oct 5, 2009 | 10:56 AM
snook's Avatar
snook
It's intermittent the light works sometimes and then doesnt work other times
still have not figured it out
if I flip the lights on and off it starts to work
Does this sound like I need a relay?
Old Dec 3, 2009 | 08:38 PM
LeMoine's Avatar
LeMoine
I know this thread is old but did you ever find a solution to this problem im having the same issue
Old Dec 3, 2009 | 08:51 PM
snook's Avatar
snook
Yes sorry I didnt post it was the balast after all that **** I had to go through to figure it out, what a pain in the butt
Old Dec 3, 2009 | 10:59 PM
UTSC300's Avatar
UTSC300
mine is doing it too, but thats with even going to a new ballast . it sucks. i have to flick the switch on and off a couple times to get it too fire. probly look like a jackass when doing it
Old Dec 4, 2009 | 01:23 AM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
HID flicker/shut off problems happen because people hook them up incorrectly. Most HID manufacturers/sellers/retailers will NOT tell you that you need a relay harness in order for the HID kit to function properly; just because they want to sell you their product, they could careless if it works for you. What an HID relay harness does essentially is draw juice/power DIRECTLY from the battery in a car that did not come from the factory with HIDs. Drawing power from the battery directly when you switch the headlights/foglights on prevents a rough current draw from your stock headlight harnesses/bulb sockets. You'll notice on an HID relay harness, only ONE bulb socket is used instead of 2 sockets when not using the harness. The fix is quite simple. Go on eBay, type in '9006 relay' (for low beam projector HIDs) and 'H3 relay' (if you have fog light HIDs). They are usually $10 shipped and VERY self-explanatory to hook up if you know basic positive/negative electrical work on a car. Your problem will be fixed. The problem is/was that you are hooking those HIDs up to a stock headlight harness/bulb socket and the stock wiring CANNOT handle these power loads. I can guarantee you that if you get the HID relays harnesses off eBay or elsewhere, you will not have anymore problems with your HIDs, and if you still do, then there is something wrong with the kit. I would actually take out the HID kit(s) you have installed UNTIL you get the relay harness(es) installed properly for the kit(s) because you are damaging the bulbs/ballasts with them flickering/shutting off. You'd be surprised at HOW MANY PEOPLE install aftermarket HIDs totally incorrectly. But it is all a learning process. Hope this helps.
Old Dec 4, 2009 | 01:24 AM
ALLWiTE2JZ's Avatar
ALLWiTE2JZ
LOL!!!!!!! I used to do that all the time when I was new to HID kits too. Read my last post to understand better. Hope it helps.
Old Dec 4, 2009 | 02:11 AM
j three's Avatar
j three
Did you get the 35 or 55 watt DDM kit?
Old Dec 4, 2009 | 08:21 AM
snook's Avatar
snook
Mine is the 55w 6000k DDM Kit. No harness works perfect now that they sent me a new ballast that isn't faulty.
I see no reason to get the harness since my lights are working now.
Just return your kit and get the ddm 55w kit. If you end up needing the harness which since we have the same car you shouldn't, they sell it for 20
Old Dec 4, 2009 | 11:38 AM
PaulFMcG's Avatar
PaulFMcG
I am new here...having a similar issue.
Its with my OEM HID Head lights...
Left light kept going out so I assumed I needed a new bulb, bought 2 new bulbs on eBay 6000k bulbs...
Now when I run the bulbs...the both go off after about 5 mins or so...
If i turn the lights off and back on, they will fire up, but then go off again after about 5 mins???
Any ideas?
Thanx All =)
Old Oct 21, 2013 | 11:45 AM
bueck's Avatar
bueck
I see this is an old thread but I am still having the same problem with OEM HID lights. Has anyone found the real answer to this problem??????
Old Nov 30, 2013 | 03:34 PM
Spriggan's Avatar
Spriggan
Experiencing the same issue on my 2007 is250 with OEM bulbs and ballasts. Mostly the passenger side, but sometimes the drivers or both?!? Going to try pulling the bulbs to check for hazing and replace with new D4S bulbs. Hopefully that will solve this frustrating issue.
whitecel
Lighting
May 22, 2010 04:43 PM
06MiCa
May 26, 2009 04:11 PM
GGGXXX
GX - 1st Gen (2003-2009)
May 16, 2007 10:02 PM
stefnee
May 12, 2007 02:46 PM
