Gas: Premium vs. Regular advantages, disadvantages (merged threads)
a better question is which is better, Chevron supreme or the new Shell V-Power.
I read somewhere that if the car says premium gas required, you should use premium only, but if it says Premium gas recommended you can use anything.
I've also heard the MPG argument. Didn't someone on the forum do a prolonged test with both looking at MPG?
However, you will experience slightly less mpg (although not nearly enough to offset the 20 to 30 cent a gallon savings of regular over high test), and your performance will be slightly less than optimal (although not enough to notice unless you are using a stop watch calibrated in hundredths of a second).
I have a 1995 Infiniti Q45a that has had nothing but regular gas since 1998. The car has 171,000 miles on it and the engine runs like new. Once in a great while I fill it with 94 octane. I can't tell any significant difference in gas mileage nor power.
BTW, while we're at it, I use synthethic oil and change it and the filter religiously every 10,000 miles, whether it needs it or not!
PS
I average 19.8 MPG with my LS600.
I can't say specifically if there is any difference between these two, but for most brands there is absolutely no difference. All gasoline in the US is refined in either Texas or Louisiana (and maybe a little in CA and a couple other states). Once its refined by any refiner, its fed into a pipeline for transport to various fuel terminals around the country. All refiners use the same pipelines. Once it comes out of the pipeline at the other end, no refiner knows it was their gas they put in at the other end.
For example, Chevron puts 500,000 gallons of 89 octane into the pipeline in Louisiana and at the same time Shell puts in 700,000 gallons of 89 octane. When the gas reaches Philadelphia, neither company knows which gas they actually put in. All they know is 500,000 gallons goes to Chevron and 700,000 goes to Shell. And since Shell has too much, they sell off 300,000 gallons to Costco, Al's Discount Gas and any other off brand station who will buy it.
Now what can happen is when Shell claims the gas and puts it in their storage tanks in Phil., then may put their own additives in. If they do though, its also in Costco's and Al's brands as well. Now of course if Al decides to add water to his gas, its not going to run as well in your car!
Here's my logic:
For the sake of argument, let's say it takes about 18 gallons to fill up your tank when close to empty.
In most locations, difference between premium and regular is 20 cents a gallon. Thus, if you fill it up using regular gas, you will be saving (18 X $.20) which is $3.60 per fill up.
OK, let's say you fill up about once per week, that's $3.60/week, which equates to $14.40/month, which equates to about $172.80 per year.
Now comes the million dollar question, is it worth ruining the finesse of a LS460 in order to save approx. $200/year?
Surely, the engineers at Toyota did not just sit one day and decide to invonvenience us by requiring premium grade fuel....Or, did they?
