Sponsored by: CARiD
2Gs Stock HID bulb replacement
Old Sep 16, 2009 | 08:05 PM
MrMarkus's Avatar
MrMarkus
Default 2Gs Stock HID bulb replacement
So I changed my city lights to LEDs and now my city lights look blue and my stock HID's look more white. I want to match these and have already tried many different LED bulbs in hopes of matching it with the stock HID headlights.
I'm thinking about switching my stock HID bulbs to a higher temp/blue color bulb. Is it possible to switch the stock HID bulbs with aftemarket ones without changing the stock ballast?
If so can anyone suggest a bulb that will match the blueish LED city lights?
My LED are super white by PIAA but look more blue than white.
Any help is much appreciated
Old Sep 16, 2009 | 09:04 PM
emoshun's Avatar
emoshun
Philips Ultinon D2R 6000k
eBay item #310163235905
Old Sep 17, 2009 | 10:04 PM
MrMarkus's Avatar
MrMarkus
Thanks for the response...so i checked them out and the description describes these 6000k bulbs of having a purplish hue?
i know different brands vary in shades but are these more purple than blue? Question....i'm assuming my stock HID's are 5000k and it seems replacing the bulbs with 6000K will work fine. What about 8000k? can I still use the same stock ballast? Can i use any 6000k/8000k HID bulb like PIAA for example?
Old Sep 17, 2009 | 10:32 PM
emoshun's Avatar
emoshun
I wouldn't go higher than 6000k for the sake of the bulbs ability to illuminate the road. You lose output intensity the higher you go in the kelvin scale.
4300k is stock, 5000k & 6000k are the only aftermarket bulbs that Philips makes.
Stick with Philips seeing it's what you have stock, they have the highest quality standards, and will not fail prematurely or color shift like other chinese bulbs.
Good luck!
Old Sep 17, 2009 | 10:47 PM
MrMarkus's Avatar
MrMarkus
sounds good thanks for the info....i will be purchasing bulbs shortly. I'll let you know how it goes. Thanks again!
Old Sep 27, 2009 | 03:26 AM
LexusK's Avatar
LexusK
WAITTTT!!! Theres a thread in the 2GS forums about this. I have the leds from ebay sold by a seller who goes by the name of Warden..something. They match perfectly!!
Old Sep 29, 2009 | 03:39 PM
Legends6spd's Avatar
Legends6spd
lexusK, which one did you buy exactly?
also, which high beam bulbs did u buy so that DRL will match?
Old Sep 30, 2009 | 11:19 PM
MrMarkus's Avatar
MrMarkus
so i finally changed my stock HID bulbs with Xenon 6000k D2R bulbs. After hours of trying to install the bulbs I finally decided to take off the front bumper. While I had the bumper off i decided to also upgrade my fog lights with the Xenon 6000k HID upgrade which was a direct plug and play.
I did not upgrade my high beams simply because the high beams are also my day lights. I didn't want to go through all the re-wiring of everything.
The 6000k Xenon bulbs definiely are much brighter and have more of a blueish tint compared to the stock HID bulbs, however I am still stuck with unmatching city lights. I am currently using PIAA led bulbs for my city lights (which seem to look more purple than anything) and have just ordered some HID led's from V-Led.com. Hopefully these bulbs will finally match.
Thanks for all the input guys....I'm definitely glad I upgraded my bulbs. I didn't think they were gonna make that much of a difference!
brociouz
Aug 3, 2010 08:15 AM
uaaction
Jul 6, 2009 10:43 AM
is250al
Nov 7, 2007 12:19 PM
skyraven4
Oct 15, 2007 06:06 PM
beauphus
Apr 13, 2005 04:35 PM
