02 touch screen not working
Old Sep 11, 2009 | 02:26 PM
lovelexus2's Avatar
lovelexus2
Smile 02 touch screen not working
Thanks in advance for anybody here who give your advise.
I just got a 02 LS430, the touch screen is not working, I can't touch the "I agree or anything " to get the GPS start. For everything else, AC,Audio or others, I can't control them by the touch screen as well. i am wondering if anybody had this problem before. Do I have to take to dealer? I bet it will be very expensive. Also I have heard that if the disc was missing which can cause this kind of problem? If the disc is missing,do i have to order fromt the dealer, and since I am the owner of the car, will they give me one for free??
Also the warning keep showing up: low engine oil level. However I have checked couple times, the engine oil looks pretty good, it still has 1000 more miles before next service. anybody know about this problem? could it be the sensor?
thanks
Old Nov 16, 2009 | 07:07 PM
joe422's Avatar
joe422
Did you get this fixed?
Anybody else have this problem? Our LS430 had intermittent touchscreen problems too, and now wont work. Mainly at startup, the "I agree" corner does not respond... heck the whole lower portion doesn't respond. If I press climate, some of the areas in the middle will respond to touch, but not the lower part of the screen.
Anyone ever fix this?
I updated the Navi disk a couple yrs ago. Bought it oem from dealer.
Old Nov 17, 2009 | 05:43 AM
toantran99's Avatar
toantran99
Might have to replace the screen portion.
Old Nov 17, 2009 | 03:59 PM
ebolger's Avatar
ebolger
Have you had the Lexus Link disconnected?
I had that problem when I bought my '01 7 months ago but had the same problem. Found out that the Lexus Link was not supported in the older 430's. Went to the dealer...$135 later everything worked fine.
Old Nov 17, 2009 | 04:58 PM
Slvr surfr's Avatar
Slvr surfr
I have an 05 and had this happen on two occasion in on cold mornings. Couldn't hit the agree button but heard the music playin. After several screen presses, i get a notice about the nav disc malfunctioning. Got to my destination only after a couple of minutes a turned the car off. Next time i started it it was working fine. I think maybe it acts funny in colder weather or maybe the disc and/or nav laser is dirty. Will try to clean and see what happends.
Old Jan 13, 2010 | 03:00 PM
joe42276's Avatar
joe42276
Anyone have touchscreen problems too?
We do have Lexus Link, and didnt remove it yet... ('01 LS430 UL)
Has anyone fixed this issue yet?
Old Mar 9, 2010 | 02:10 PM
lovelexus2's Avatar
lovelexus2
Bought a used one from Ebay, replace it and everything works just fine.
Old Jun 4, 2010 | 12:31 PM
joe42276's Avatar
joe42276
Thanks!
I did the same. Found a used one on ebay ($350)... crossed my fingers, and perfect! I did swap in my bezel and some of the buttons as mine were in better condition. The screen works perfect though.
Easy 10 min install.
Old Jun 4, 2010 | 12:52 PM
lovelexus2's Avatar
lovelexus2
That is great, congratulations
Old Jun 4, 2010 | 04:14 PM
Bocatrip's Avatar
Bocatrip
Are you talking about buying an entire used nav system? Are these systems known to have problems? I am looking for a 2001-2003 LS430 and was considering staying away from those cars with Nav. Should I be concerned?
Old Jun 4, 2010 | 04:20 PM
joe42276's Avatar
joe42276
The problem doesn't seem common.. being that it was so hard to find any good info or solutions for a while.
In my case, the upper 1/3 and lower 1/3 was numb to the touch. It would not respond. It started out as a sporadic problem... not consistent... and later, it was just stopped responding.
The Ebay part I bought included the actual screen... the bezel surrounding it and the button along the side of the screen, as well as the center vent outlet.
I only utilized the screen itself. It's fairly easy to replace.
Old Jun 4, 2010 | 07:50 PM
biga27110's Avatar
biga27110
thanks for this great post guys
Old Jun 7, 2010 | 09:55 AM
joe42276's Avatar
joe42276
Oh yea... the plastic bezel for the navi screen that goes up over the center vents, would squeak from time to time. Nothing could solve it.. not even the dealer (yrs ago).
Anyway, while I was replacing the nav screen, I also bought a roll of 1mm felt tape... and stuck it neatly onto the bezel (where it will touch the vinyl on the dash). Voila... perfect! No more squeaks! Just silence.
Old Jun 7, 2010 | 05:10 PM
randal's Avatar
randal
Joe, can you tell me how to remove the bezel? I also have the squeak occasionally and would like to do the felt treatment.
Old Jun 7, 2010 | 05:36 PM
joe42276's Avatar
joe42276
You'll have to start from the bottom and disassemble / pull each segment out from the shfter center console on up.
JermSJ
NX - 1st Gen (2015-2021)
Mar 21, 2019 08:04 PM
FraganciaF
IS F (2008-2014)
22
Feb 12, 2015 05:27 PM
FastTags
Jun 6, 2014 05:17 PM
boglow
May 25, 2010 09:24 AM
Jooleee
Dec 15, 2003 09:51 PM
