Tweak tip for auto Sc shifting!
Old Oct 21, 2008 | 11:57 PM
  #46
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Didn't do a thing to mine any of the 30 or so times I've screwed with it. Just made it drop into gear smoother and changed the shift behavior.
Old Oct 22, 2008 | 03:46 PM
  #47
over40driv's Avatar
over40driv
Tried the clockwise turn on my TPS today, just enough to make a diff. It idles to high, but seemed to shift better. I tried to set it back and then the idle was to low . Going to split the diff. next to get back to 800 RPM idle.
Old Nov 18, 2008 | 10:56 PM
  #48
Mick's Avatar
Mick
Well I found this thread while searching possible problems with my transmission after having transmission flushed (see rant in maintanence) but my question is, is this tweaked during a transmission flush or is this sudden jerking into gear on cold starts a problem from having my tranmission serviced at a car wash?
I plan on doing this tweak but will I only be putting a bandaid on something that could turn out more serious in the future???
Old Aug 23, 2009 | 09:20 PM
  #49
b1ackhawk's Avatar
b1ackhawk
CL Folding 3,000,000
so would this have a similar effect as adjusting the line pressure via the adjustment screw in the trans?
Would there be any adverse affect to raising the line pressure via this method other than a harder shift?
Old Sep 3, 2009 | 07:17 AM
  #50
1siksc's Avatar
1siksc
Thanks O.L.T. My car has always been shifting hard into D since i've done the swap... Not anymore!
Old Nov 2, 2009 | 03:49 PM
  #51
SEXY 400's Avatar
SEXY 400
Originally Posted by vwynn
hmm then what explains those.. CRAZY Jolts that happen once every other week?
like i remember warming up my car.. n then got in to drive. Pop it in reverse holdin on brake. n BAM the car jolts back like.. a big sudden shock.
wierd? or something is bad?
but this mod.. has anyone turned it right?? haha
I just tried this today on the SC400 and turned it counter-clock wise it fixed the clunking when shifting in all gears from P to 1st. I think a good transmission drain and fill (several times) really helped. Cheers!
-Nick
Old Sep 15, 2013 | 08:13 PM
  #52
Brianmoss's Avatar
Brianmoss
This thread needs to be a sticky... Worked wonders.
Old Sep 27, 2015 | 04:23 PM
  #53
SEIDO's Avatar
SEIDO
I did this today, and it does feel better; as if the shifts are smoother.
The idle upon start-up was at 1200, but after a brief drive (1.5mi) it fell down to 800 at the red light.
Switching from D to R and back again, seems smoother also; no "clunk" ...
So I think it worked; however I didn't have to move it very far. The TPS was just short of fully-left; I only had to adjust it about 1/4". Perhaps the original owner attempted this mod, 'cus I've never touched the TPS until now.
Just to be certain though, since mine's an SC300, which one's the TPS?
I assumed it's #2, since thats the same side as the throttle cable ...
If that's the case, then what's sensor #1, and what happens if I adjust that also?
Thanks!
Old Sep 27, 2015 | 05:18 PM
  #54
t2d2's Avatar
t2d2
^ Sensor #1 would be TRAC.
I can't say this tip makes any sense to me, although I didn't read pages 2 and 3. Adjusting the TPS doesn't seem like it should have any affect on the transmission's smoothness of shifting -- that's what the transmission throttle cable is for -- but would have other adverse drivability effects. Maybe one is covering for the other, but it seems like the wrong way of going about it.
Old Sep 28, 2015 | 05:37 PM
  #55
bigwhite's Avatar
bigwhite
Im still having hard jerk from park to drive. The detent cable barely has any tension on it at idle and moving the TPS did not fix the prob. I also have new trans. mount and steering rack bushings.
Old Sep 29, 2015 | 03:43 PM
  #56
bigwhite's Avatar
bigwhite
Other than the rough shift into drive, my car runs excellent. Does anyone think my TPS could be faulty and not affecting transmission?
Old Sep 29, 2015 | 06:51 PM
  #57
t2d2's Avatar
t2d2
From everything I've read, that's a mechanical thing and is just the nature of the transmission. To prove otherwise would probably require input from one of the few people who bought their SC new and can vouch for how it behaved initially.
Old Sep 30, 2015 | 03:50 PM
  #58
bigwhite's Avatar
bigwhite
I had a 95 SC400 for 4yrs, always shifted into drive smoothly. I owned this car for 4 yrs. and it did the same, until the engine and trans, were removed from the car. I always thought that the TPS was a major player in the performance of OBD1 cars, because such a big deal is made out of the exact setting of them. Now im remembering that the MAF, temp. sensor, ECU and 02 sensors are prob. bigger players of the engine fuel/air control than the TPS?
Old Sep 30, 2015 | 04:06 PM
  #59
bigwhite's Avatar
bigwhite
So I just watched a video on rockauto, concerning an airtex TPS and it said the synptom caused by a faulty TPS is hesitation on acceleration.
Old Sep 30, 2015 | 05:10 PM
  #60
t2d2's Avatar
t2d2
That would be the normal symptom attributed to it. Unless someone comes along with a solid explanation of how the TPS affects the smoothness of the shifts themselves, I call B.S.
